pontiac vibe 2008
trung291
Posted: July 11, 2009 at 12:16 AM / IP Logged
Hello, I need a wiring diagram for a 2008 Pontiac vibe . Thank
chev104275
Gold - Posts: 1,436
Posted: July 11, 2009 at 5:37 AM / IP Logged
Battery BLACK (+) IGNITION SWITCH HARNESS
Ignition 1 BLACK / YELLOW (+) IGNITION SWITCH HARNESS
Ignition 2 BLACK/ WHITE (+) IGNITION SWITCH HARNESS
Accessory 1 BLUE/RED (+) IGNITION SWITCH HARNESS
Starter 1 RED (+) IGNITION SWITCH HARNESS
Tachometer BLACK (-) AT PCM MODULE UNDER GLOVEBOX
Crankshaft Sensor BLACK (+) AT PCM MODULE UNDER GLOVEBOX
Camshaft Sensor BLACK (+) AT PCM MODULE UNDER GLOVEBOX
Speed Sense VIOLET/WHITE (+) AT GAUGE CLUSTER HARNESS BEHIND DASH
Parking Lights GREEN / WHITE (-) AT VEHICLE LIGHT SWITCH HARNESS
Brake Lights GREEN / WHITE (+) AT SWITCH ABOVE BRAKE PEDAL
Reverse Lights RED / BLACK (+) IN HARNESS BEHIND TRIM IN LEFT SIDE OF CARGO AREA
Horn GREEN/ YELLOW (-) IGNITION SWITCH HARNESS
Power Unlock BLUE / YELLOW (-) AT THEFT MODULE BEHIND RIGHT SIDE OF DASH NEXT TO GLOVEBOX
PowerLock GREEN & WHITE (-) AT THEFT MODULE BEHIND RIGHT SIDE OF DASH NEXT TO GLOVEBOX
PIN #7 & #19 - YOU MUST DIODE ISOLATE THE UNLOCK PULSE FROM THE ALARM UNIT TO AVOID FEEDBACK.
trung291
Posted: July 11, 2009 at 11:59 AM / IP Logged
thanks for your posting
but the wiring diagram you send me it not for 2008 vibe  may be for 2007 can you check it out plz
chev104275
Gold - Posts: 1,436
Posted: July 11, 2009 at 12:32 PM / IP Logged
diagram says 08   but this diagram has the wires in different locations but uses the same colors
VIBE   2008 -
PART   COLOR LOCATION DIAGRAM
12 VOLT CONSTANT   WHITE (+)    IGNITION SWITCH HARNESS
STARTER RED (+)   IGNITION SWITCH HARNESS
STARTER 2 N/A N/A
IGNITION 1 BLACK/ WHITE (+) IGNITION SWITCH HARNESS
IGNITION 2 BLACK / YELLOW (+) IGNITION SWITCH HARNESS
IGNITION 3 N/A   N/A
ACCESSORY /HEATER BLOWER 1 BLUE/RED (+)   IGNITION SWITCH HARNESS
ACCESSORY /HEATER BLOWER 2 N/A   N/A
KEYSENSE BLUE/BLACK (-)   IGNITION SWITCH HARNESS
PARKING LIGHTS ( - ) GREEN / WHITE (-)   AT HEADLIGHT SWITCH ( #775 RELAY REQUIRED )
PARKING LIGHTS ( + ) N/A   N/A
POWER LOCK GREEN (-)TYPE B   WHITE CONNECTOR IN DRIVERS KICK PANEL
POWER UNLOCK BLUE / YELLOW (-)TYPE B REQUIRES DOUBLE PULSE UNLOCK   AT WHITE CONNECTOR IN DRIVERS KICK PANEL
LOCK MOTOR WIRE N/A   N/A
DOOR TRIGGER RED / WHITE (-)   AT INSTRUMENT CLUSTER PIN 26
DOMELIGHT SUPERVISION N/A   N/A
TRUNK RELEASE N/A   N/A
SLIDING POWER DOOR N/A   N/A
HORN GREEN/ YELLOW (-)   STEERING COLUMN HARNESS
TACH BLACK   AT INSTRUMENT CLUSTER PIN 27
WAIT TO START LIGHT N/A   N/A
BRAKE GREEN / WHITE (+)   AT SWITCH ABOVE BRAKE PEDAL OR DRIVERS KICK PANEL
FACTORY ALARM DISARM   N/A   N/A
ANTI-THEFT TRANSPONDER ANTI-THEFT   TRANSPONDER @ IGNITION SWITCH TUMBLER
Chris Luongo
Platinum - Posts: 3,746
Posted: July 12, 2009 at 10:56 AM / IP Logged
I see that you're in Canada, but the US Vibe should be identical from 2003-2008. The 2009 is an all new model.
Any tech sheet that a U.S. based person gives you will be the same for 2007 and 2008.
Again, your Canadian car may be different.
Tuesday, February 3, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
