ida x200
imupabove
Copper - Posts: 369
Posted: July 28, 2009 at 1:18 AM / IP Logged
on my headunit i set my bass all the way down. and i set the bass bandwidth at 4. having a little trouble on the frequencies for the bass; when i put the frequency at 200 by sub gets really loud but my highs dont sound so clear and loud. but when i put the bass frequency at 60 my highs sound good but not that much power coming from my sub. i tried "EQing" it myself but cant seem to get it right. thanks and peace.
yimke
Copper - Posts: 417
Posted: July 28, 2009 at 9:32 AM / IP Logged
Do you have the HP filter set on your amp instead of a LP? Because it is doing the opposite of what it should be doing. That or you maybe have the RCA's not plugged in the subwoofer RCA output.
imupabove
Copper - Posts: 369
Posted: July 28, 2009 at 11:53 AM / IP Logged
are you talking about the 4 channel amp? it suppose to be set a HP. and all my RCA's are good.
spmpdr
Copper - Posts: 456
Posted: July 28, 2009 at 4:51 PM / IP Logged
Does your 4 channel have a hp and lp filter.If it does make sure that all your wiring to the sub is set to the lp channels and all the wiring for the mids/highs is set to the h/p channels.It sounds like something is backwards with your wiring double check that if you havent already.
-A vision without a plan is just a hallucination-
imupabove
Copper - Posts: 369
Posted: July 29, 2009 at 1:26 AM / IP Logged
yes everything wired correctly. what do you mean "sub is set to the lp channels?
spmpdr
Copper - Posts: 456
Posted: July 29, 2009 at 10:17 AM / IP Logged
Most 4 channels have a h/p filter that is set to two channels of the amp and l/p filter set to two channels of the amp.I was thinking that maybe you had your sub connected to your h/p channels.Try your bass frequency at 80 and set your mids /highs correctly with your gain.Also make sure your gain is set properly for both your bass and mid/highs
imupabove
Copper - Posts: 369
Posted: July 29, 2009 at 3:40 PM / IP Logged
yeah the amp is on 4 channel and set on HP. ima double check though. also im going to see if i can EQ it better. thanks for the help.
spmpdr
Copper - Posts: 456
Posted: July 29, 2009 at 7:17 PM / IP Logged
does your amp have h/p and l/p or only h/p? if it has both yo need to figure out which of the four channels is l/p and hook those 2 up to your sub with the l/p on.the other 2 channels should run your mids /highs with your h/p off or on depending on whether or not you have a crossover .could you please list your entire setup?
imupabove
Copper - Posts: 369
Posted: July 29, 2009 at 9:22 PM / IP Logged
IDA-X200
MRP-M500
12" ALPINE TYPE R
RF PUNCH 240X4
6022I'S (FRONT)
SPS-69C3'S (REAR)
RFCD1
the rf punch amp is old. it only has a gain. no bass EQ. and it has a micro chip, i can choose hp or lp. and has a switch for 2 channel and 4 channel. i have it at hp and 4 channel. check out the manual. RF Punch 240x4
spmpdr
Copper - Posts: 456
Posted: July 30, 2009 at 12:40 AM / IP Logged
Is the RF powering your subs? I think its the mrp-500 but just want to be sure.Your four channel should be powering your front and rear speakers.not your sub. I would set your bass at 80 and set your highs as best you could and call it good with that old amp . Or get a new 4 channel with more features.
