Wiring Info for Sebring Vert.
ILuvItLoud
Member - Posts: 16
Posted: March 27, 2003 at 8:37 PM / IP Logged
Hi, I am planning on installing my Viper 790xp in my 97 Chrysler Sebring this weekend. I basically know how to do it but I need a little help with the door locks. I see that they are a single wire system, so do they even need relays or just some sort of resisters? A diagram would be nice if someone could post it. Thanks
Platinum - Posts: 12,488
Posted: March 29, 2003 at 7:07 AM / IP Logged
<"http://www.velocitymotorsport.com/images/security/ball.gif" border="0"> Positive Single Door Lock Diagram
The target wire is WHITE/ GREEN found to the rear of the fuse box under the dash. Door locks are positive trigger, must use relays. Lock is a straight positive trigger, unlock requires a positive trigger with a 1500 ohm resistor wired in series.
ILuvItLoud
Member - Posts: 16
Posted: March 30, 2003 at 5:17 PM / IP Logged
Thanks a lot, Jeff. You seen to be very knowledgeable on this board. I appreciate your help man.
Leon
