2009 ford edge parking lights
wherman
Posted: August 08, 2009 at 7:13 PM / IP Logged
I have an Ford Code Systems RS installed and working except for the parking lights, the wiring calls for a violet/white trace wire in the drivers kick panel. I've found several matching wires but none test correctly.  The brake also the same color wire and one of the wires in the kick panel shows 12V when the brake is depressed.  Any other way to id the correct wire? or location.
WHerman
Platinum - Posts: 13,726
Posted: August 08, 2009 at 7:26 PM / IP Logged
If you have the right brake wire, it will show 12 volts when the pedal is depressed.  Release the pedal and the 12 volts goes away, I would have to believe that this is the correct wire.
I have the same info you have for the parking lights.
mikvot
Gold - Posts: 1,043
Posted: August 08, 2009 at 8:59 PM / IP Logged
Yep, parklights are violet/white. They are in the huge harness against the firewall, and runs down into the kick panel.
KarTuneMan
Platinum - Posts: 7,056
Posted: August 09, 2009 at 1:11 AM / IP Logged
(POS)+ lights.... negative, not so easy!
mikvot
Gold - Posts: 1,043
Posted: August 09, 2009 at 2:27 AM / IP Logged
Whhaat? I don't get it? I'm confirming a location....i'm not confirming a polarity....he already has tech info that says violet/white.....now it is his job to find the wire, and test with a multimeter.
mikvot
Gold - Posts: 1,043
Posted: August 09, 2009 at 2:40 AM / IP Logged
For the brake, just go directly to the brake switch.... the wire will test 12 volts when the brake pedal is pressed down. Not that the wire can't be found elsewhere...but I would take it directly from the source if you can't find it in the kick.
KarTuneMan
Posted: August 09, 2009 at 1:52 PM / IP Logged
Sorry!
richl68
Copper - Posts: 107
Posted: August 09, 2009 at 2:45 PM / IP Logged
same info here
Parking Lights (+)PURPLE / white+driver kick or SJB, black 32 pin plug (D), pin 20
The SJB (Smart Junction Box) is under the driver dash.
wherman
Posted: August 09, 2009 at 5:42 PM / IP Logged
Thanks for all the replys, I'll try the SJB.
WHerman
