2003 Kia Sedona, Back-Up Wire
windrider
Member - Posts: 14
Posted: August 09, 2009 at 2:06 PM / IP Logged
can someone tell me the best location in the front to find a hook up for the back-up wire?
Platinum - Posts: 13,725
Posted: August 09, 2009 at 7:47 PM / IP Logged
You tell us what year the car is, and I am betting we can help you.
Posted: August 09, 2009 at 7:55 PM / IP Logged
08 =
2003 Kia Sedona, Back-Up Wire - Last Post -- posted image.Reverse LightsRED(+)AT FRONT ACCESS MODULE UNDER HOOD
07 =
2003 Kia Sedona, Back-Up Wire - Last Post -- posted image.Reverse LightsRED(+)RAM MODULE
Note for 07 reads PIN #19 OR 20 (40 PIN PLUG)
06 = Same as 07
05 =
Reverse LightsRED / GREEN(+)
HARNESS TO REAR DR KICK
04 =
Reverse LightsGREEN(+)@ PCM PIN D 20
03 = Same as 04
02 = Same as 03 and 04
Posted: August 10, 2009 at 3:28 AM / IP Logged
Read the post about the VW 2005, it also tells you how to find it. Anyway here goes. Go to the back with ignition and parking brake on, and gear shift in reverse.  Check which wire to lens cluster goes live then shuts down when you go out of reverse, then go to one of the kick panels and find the thickest floor loom, find the same colour wire and check it there.  If this was Japanese, I would say look for a primary clolour green wire.
windrider
Member - Posts: 14
Posted: August 11, 2009 at 12:08 PM / IP Logged
the car is a 2003 kia sedona
Posted: August 11, 2009 at 7:54 PM / IP Logged
i am an idiot wrote:
08 =
07 =
06 = Same as 07
05 =
04 =
03 = Same as 04
