07 dodge ram with no starter wire
jromero1297
Posted: August 18, 2009 at 4:03 PM / IP Logged
can anyone one tell me how to wire up the clifford 50.5x remote start to this truck. everything is - on it. is it as simple as it sound? just use relays to reverse the polarity. thanks in advance for your time
Platinum - Posts: 13,726
Posted: August 18, 2009 at 4:44 PM / IP Logged
07 dodge ram with no starter wire - Last Post -- posted image.Accessory 1VIOLET/BROWN(-)IGNITION HARNESS07 dodge ram with no starter wire - Last Post -- posted image.
07 dodge ram with no starter wire - Last Post -- posted image.Starter 1YELLOW/GRAY(+)GRAY PLUG NEAR BATTERY, NOT FOR REMOTE START07 dodge ram with no starter wire - Last Post -- posted image.
07 dodge ram with no starter wire - Last Post -- posted image.Starter 2VIOLET/BROWN(-)IGNITION HARNESS
If you notice the Acc wire and the starter 2 wire are the same wire, the notes say to ground that wire through a 100 ohm resistor for start.  Ground the same wire throught a 610 Ohm resistor for Acc.
Ground terminal 85 and 30 of each relay.  86 of the start relay connects to the start wire of your remote start unit.  Connect the 100 ohm resistor to terminal 87.  Coneect the other end of the resistor to the Violet/Brown wire.
86 of the Acc relay connects to the Acc wire of the remote start unit.  87 connects to the 610 ohm resistor.  The other end of the 610 ohm resistor connects to the Violet/Brown wire.
Key sense also uses the same wire.  The resistor value for that is 8.5K
