need wiring diagram for 2007 suzuki reno
ridin_low07
Posted: August 21, 2009 at 11:21 PM / IP Logged
I bought my brothers cd player out of his 2007 Reno after he totalled it so I could retro fit it into my girlfriends 93 Beretta. The problem that I am running into is the wiring. It has an 18 PIN connector that I am not quite sure where everything wires up to. I know the speaker wiring because it says it on there but others are just confusing. This is a list of what is on there...........
1.Front R-Ch (+)
2.Rear R-Ch (+)
3.Illumination
4.Acc B+   ??
5.Back-Up B+   ??
6.Phone Mute  ??
7.Rear L-Ch (+)
8.Front L-Ch (+)
9.Front R-Ch (-)
10.Rear R-Ch (-)
11.Illumination (-)
12.Auto Ant B (+)   Don't have a power antenna so I don't need this one
13.Remocon Ground  ??
14.Ground
15. N.C. ????
16.Front Remocon Data  ???
17.Rear L-Ch (-)
18.Front L-Ch (-)
If anyone can help me out I would be really appreciative.
Platinum - Posts: 13,725
Posted: August 21, 2009 at 11:32 PM / IP Logged
Acc B+ = Switched 12 volts.  This wire turns the radio on when you turn the key on.
Back Up B+ = Constant 12 volts, this wire needs 12 volts on it even when the key is not turned on.
N. C. = No Connection
Phone mute mutes the audio when you are on the cell phone, if your cell phone has a mute output wire.
Disregard the remote control wires.
ridin_low07
Posted: September 10, 2009 at 7:49 PM / IP Logged
thanks man i got it all wired up and working now I just have to figure out the illumination and ill be all set.
