what would be the best amp?
jsmiley
Posted: September 12, 2009 at 6:37 AM / IP Logged
I have two kicker cvr's dual 2 ohms, what would be the best amp.
I was recommended: is that good?
Sound Storm (SSL) F2600D
2600W Max, Class D Monoblock Power Amplifier
SSL Series Monoblock Class D Car Amplifier • 750 Watts x 1 Chan. @ 4 Ohms • 1200 Watts x 1 Chan. @ 2 Ohms • 2600 Watts x 1 Chan. @ 1 Ohms • MOSFET PWM Power Supply • Nickel-Plated RCA Level And Screw Terminals
Smilry
tommy...
Gold - Posts: 1,901
Posted: September 12, 2009 at 8:07 AM / IP Logged
We do sell a few soundstorm amps here and there...But for the most part...They are junk...! ITs funny...When i sell one... most of the customers thinks its soundstream...! How much is the amp...What do you want to spend...?
M.E.C.P & First-Class
jsmiley
Posted: September 12, 2009 at 12:12 PM / IP Logged
The amp cost 149.99 online.
But I'm willing to spend 200 nuthin too outrageous. But I want an amp that is going to push my subs though. Aha make the trunk fly off.
Smilry
tommy...
Gold - Posts: 1,901
Posted: September 12, 2009 at 12:38 PM / IP Logged
General
 TypeComponent
 Size12"
 Impedance2Ohms
 Voice Coil(s)Dual
 Sensitivity86.7dB
 Peak Power Handling800 Watts
 RMS Power Range400 Watts
 Free-AirNo
 Surround MaterialSantoprene® rubber
 Cone MaterialInject-molded polymineral
 Frequency Response25 - 500Hz
 Installation
 Cutout Diameter or Length11-1/8"
 Top Mount Depth6-5/16"
 Sealed Box Volume1.0 - 4.6cu. ft.
 Ported Box Volume1.75 - 2.25cu. ft.
 Warranty
 Parts1 Year
 Labor1 Year
Here are the specs on those subs...Lets see what we can get you into for around $200.00...! What type of enclosure are they currently in...? Is there something already installed in the car, or does the amp still need wires ran...? Are you installing yourself...? If so...What size power wire are you using...? Memphis makes some pretty good amps...And the on-line pricing is not bad...The one that comes to mind is the PR1.500...I dont know much about Kickers pricing...Im sure you could match something up there too...!
tommy...
Gold - Posts: 1,901
Posted: September 12, 2009 at 12:53 PM / IP Logged
Two 2 ohm Dual Voice Coil (DVC) Speakers
Option 1 (parallel/parallel) = 0.5 ohm load
Voice coils wired in parallel, speakers wired in parallel
Recommended Amplifier: Stable at 1/2 ohm mono
what would be the best amp? - Last Post -- posted image.
Option 2 (series/parallel) = 2 ohm load
Voice coils wired in series, speakers wired in parallel
Recommended Amplifier: Stable at 2 or 1 ohm mono
Option 3 (series) = 8 ohm load
All voice coils wired in series
Recommended Amplifier: Stable at 4, 2, or 1 ohm mono
Here are some wiring options for your subs...Might help in amp decision...!
jsmiley
Posted: September 12, 2009 at 7:34 PM / IP Logged
I have a vented box, the amp was giving to me its a pioneer 760 watts, it overheats alot. my power wire is an 8 gauge but im about to install a 2 gauge. Thanks for your help.
Smilry
srh23
Member - Posts: 14
Posted: September 13, 2009 at 10:56 PM / IP Logged
Look into a kicker zx750.1, its a little more expensive but its 2 ohm stable which is what you need and it will push well over the rated 750 rms. I have experience with kicker amps and they are reliable and very beasty. You wont be sorry.
haemphyst
Platinum - Posts: 5,059
Posted: September 14, 2009 at 9:11 AM / IP Logged
I really hate to be the bearer of bad news, but let's do the math:
86.7dB per woofer. Two of them nets you 89.7dB sensitivity, at 2 watts. For every doubling of power, you gain 3dB.
2, 4, 8, 16, 32, 64, 128, 256, 512, 1024
That's eight even doublings. 8 X 3 = 24dB (and a little more, as your RMS power handling is 800 watts for the pair, about half-way through the ninth doubling...)
Net sensitivity = 89.7dB, plus 24dB = 113.7dB PEAK output! HARDLY the kind of SPL I would expect to "remove your trunk lid". You need different woofers, my friend. Those are not going to make you happy, if pure SPL is what you are seeking... Even with peak power being sent to them (1600 watts) and with cabin gain, if you even make it to the mid 120's, I would be quite surprised. Now, while mid-120's is still VERY loud, it is nowhere near "SPL competition levels".
Additionally, since you can only come up with a (generally safe for nearly all readily available amplifiers today) 2-ohm load, you can expect to potentially lose up to 3dB from those numbers, due to the reduced power output from the amplifier...
DYohn
Platinum - Posts: 10,741
Posted: September 14, 2009 at 10:59 AM / IP Logged
I would not install a SoundStorm amp into my worst enemy's car.
tommy...
Gold - Posts: 1,901
Posted: September 14, 2009 at 5:03 PM / IP Logged
Make sure ground wire is same size...! Also upgrade wire from negative battery terminal to chassis ...You can probably use a little extra lenght off of power wire...! Make sure your ground is in a proper location, cleaned...etc...! Make sure you fuse for that 2 gauge...!
Monday, April 27, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
