2003 Jeep Liberty Radio Wiring
Gdubya43
Posted: March 30, 2003 at 8:23 AM / IP Logged
Could someone please send me the stereo wiring code as I want to install an aftermarket system.  I saw one on this site but it appeared to not be complete as there are many more wires in the plug connector than was shown.
Please send to gwhite@tc3net.com
Thanks Much!
Gdubya43
esmith69
Gold - Posts: 1,511
Posted: March 30, 2003 at 5:30 PM / IP Logged
AUDIO/MOBILE VIDEO
BATTERYPINK/BLACK+IGNITION SWITCH HARNESS
GROUNDBLACK-RADIO HARNESS
ACCESSORY 01RED / BLACK+IGNITION SWITCH HARNESS
DIMMERORANGE+RADIO HARNESS
FRONT LEFT SPEAKERLIGHT GREEN/ RED+
FRONT LEFT SPEAKERLIGHT GREEN/ GREEN-
FRONT RIGHT SPEAKERLIGHT BLUE/RED+
FRONT RIGHT SPEAKERLIGHT BLUE/BLACK-
REAR LEFT SPEAKERDARK GREEN / WHITE+
REAR LEFT SPEAKERWHITE/ DARK GREEN-
REAR RIGHT SPEAKERWHITE/ VIOLET+
REAR RIGHT SPEAKERTAN/DARK GREEN-
That's the wiring for the 03 grand cherokee but I'm assuming they're the same colors in your jeep liberty.  When in doubt, always check each wire's function with a DMM first though.
About the extra wires you talked about:  if you have steering wheel audio controls, then that would account for some of the unused wires.  Also, it's okay to have some wires that are not used, as most aftermarket decks only need power, +12v switched, ground, and the 8 speaker wires.
I'd highly recommend using a wiring harness instead of hardwiring--it'll make your install a lot easier and more reliable, and makes it easier to revert to factory equipment in the future.  Not to mention you won't have to worry about any of these wire colors as that's all part of the harness.  All YOU have to do is match up the colors on the aftermarket radio's harness, with the colors on the separate wiring harness you'll need to buy (such as the metra 70-6502).  Also you're probably gonna need an antenna adapter, too.
