will this relay work?
christopherrice
Member - Posts: 25
Posted: September 25, 2009 at 9:52 PM / IP Logged
Installing an auto start alarm in a 2006 Jeep Commander. Viper 5901 and iDataLink ADS-DLSL CH3. I need a relay for the Multiplex start/accessory/keysense control. I know the ones iDataLink sells are 12VDC 1A. Will this relay work instead..
DPDT
Power Consumption - 10.8 Watts
Nominal Coil Voltage - 12VDC
Nominal Coil Current - 75mA
Coil Resistance - 160 ohms +/- 10%
Pull-in Voltage - 9.6VDC
Drop-out Voltage - 1.2VDC min.
Contact Rating - 10A at 110AC or 24VDC
Maximum Operating Voltage - 250VAC/125VDC
Minimum Load - 100mA, 5VDC
Also it requires a diode on the GWR, is a N4001 alright or is there a different diode to be using?
Platinum - Posts: 13,725
Posted: September 25, 2009 at 10:23 PM / IP Logged
That relay will work fine and a 1n4001 wil be fine also.
christopherrice
Member - Posts: 25
Posted: September 25, 2009 at 11:01 PM / IP Logged
Thank you, just the answer I was hoping for.
