1998 corvette xk06
juanrs
Posted: October 13, 2009 at 9:04 PM / IP Logged
Hello everyone I'm attemtping to install a remote start on my 1998 Corvette.  I have an XK06 bypass kit flashed with PLXR firmware. I have tried all wire combos I can think of but iI still cannot get the car to start. There are two connectors on the bottom of the ignition cylinder. The connectors have the ignition, accesory, starter wires etc. There are 3 wires that i'm not sure what they are. A tan wire that shows ground but the resistance increases when i put in the key, a black wire that shows ground and a green and black wire that also shows ground.  There are also 2 white wires that come from the front of the ignition switch cylinder.
What passlock system does a 98 corvette use? passlock I, II, III
Any ideas on what wires I should connect this XK06 bypass to?
Below is a picture of my ignition switch and it's wires.
I attemtping to install it using the last page of this manual. http://bypasskit.com/getdocument.aspx?documentid=783
1998 corvette xk06 - Last Post -- posted image.
Thanks for any help!
Juan
tommy...
Gold - Posts: 1,901
Posted: October 14, 2009 at 7:24 AM / IP Logged
Here is the bypass for the VATS system... http://documents.audiovox.com/700052.pdf ... I would recommend doing away with those scotchlocks...There not supposed to be used in high current applications(remote starts)...
M.E.C.P & First-Class
tommy...
Gold - Posts: 1,901
Posted: October 14, 2009 at 7:26 AM / IP Logged
BatteryRED(+)IGNITION SWITCH HARNESS
1998 corvette xk06 - Last Post -- posted image.Ignition 1PINK(+)IGNITION SWITCH HARNESS
1998 corvette xk06 - Last Post -- posted image.Accessory 1BROWN(+)IGNITION SWITCH HARNESS...BE SURE THAT THE ACCESSORY WIRES SHUT OFF DURING CRANK OR ELSE THE CAR WILL NOT CRANK1998 corvette xk06 - Last Post -- posted image.
1998 corvette xk06 - Last Post -- posted image.Accessory 2ORANGE(+)IGNITION SWITCH HARNESS...BE SURE THAT THE ACCESSORY WIRES SHUT OFF DURING CRANK OR ELSE THE CAR WILL NOT CRANK1998 corvette xk06 - Last Post -- posted image.
1998 corvette xk06 - Last Post -- posted image.Starter 1YELLOW(+)IGNITION SWITCH HARNESS
1998 corvette xk06 - Last Post -- posted image.Anti-Theft TypeV.A.T.S
1998 corvette xk06 - Last Post -- posted image.Anti-Theft DescriptCHIP IN KEY
1998 corvette xk06 - Last Post -- posted image.Key SenseLIGHT GREEN(-)IGNITION SWITCH HARNESS
1998 corvette xk06 - Last Post -- posted image.Neutral SafetyORANGE / BLACK(-)USE START
1998 corvette xk06 - Last Post -- posted image.TachometerWHITE(AC)10 OF RD 80=PCM*
1998 corvette xk06 - Last Post -- posted image.Crankshaft SensorDARK BLUE/WHITE(-)12 OF 80 BLUE =PCM*
1998 corvette xk06 - Last Post -- posted image.Camshaft SensorBROWN / WHITE(-)73 OF 80 BLUE =PCM*
1998 corvette xk06 - Last Post -- posted image.Speed SenseDARK GREEN / WHITE(AC)50 OF RED 80=PCM*
1998 corvette xk06 - Last Post -- posted image.Parking LightsBROWN(+)DRIVER'S KICK OR MULTIFUNCTION SWITCH
1998 corvette xk06 - Last Post -- posted image.Brake LightsLIGHT BLUE(+)AT BRAKE SWITCH
1998 corvette xk06 - Last Post -- posted image.Reverse LightsDARK BLUE(+)U/HOOD RELAY=A-5 OF GRAY 68 PIN...ALSO DARK BLUE (-) AT BCM IN PASSENGER FOOTWELL1998 corvette xk06 - Last Post -- posted image.
1998 corvette xk06 - Last Post -- posted image.HornBLACK(-)AT STEERING COLUMN AND AT BCM
tommy...
Gold - Posts: 1,901
Posted: October 14, 2009 at 7:35 AM / IP Logged
From your picture it appears to be the black harness running down in the right side of the picture...Although they are usually wrapped in orange...! You have a chip a little past half-way up your key...? There is also a way to permanently bypass it...Although you lose that step of security...But the keys are cheaper to buy...Probably just stick with the bypass link i sent you(thinking out-loud)...Keep the vats...!
juanrs
Posted: October 14, 2009 at 9:15 AM / IP Logged
Ive seen that diagram before. i wish i had seen it before i spent fifty dollars on the xk06 bypass module which i cant return now :/
juanrs
Posted: October 14, 2009 at 9:20 AM / IP Logged
i know the two wires in the black heat shrink belong to the vats but i found it wierd that the tan wire coming out of the bottom of the ignition switch changes in resistance when i put in the key
tommy...
Gold - Posts: 1,901
Posted: October 18, 2009 at 9:24 AM / IP Logged
You could cut the wires for the vats and put in a resistor...One end of the resistor to each side of the 2 wires in the harness...This would be permenantly bypassed...not sure about the tan wire...Although i pretty sure it not involved with the vats...! Ot at least the bypassing of!
