viper 5701 remote programming
wgrassie
Member - Posts: 8
Posted: November 03, 2009 at 10:59 AM / IP Logged
1993 Sentra GXE
Hi
I installed th Viper 5701 in my 1993 Sentar GXE- experiencing the following issue:
Step 3 - Getting into Automatic Transmission Mode for Remote Start Function-
  • Need to change to Automatic Transmission from default Manual Mode
  •  When I press and hold the valet switch (per Automatic/Manual Programming) the LED does not flash 3 times (no flashes at all)  Siren chirps 3 times (no chirps at all)
  • The alarm functions of arm and disarm work - Remote Learn (Default Setup) completed succesfully - alarm sounds etc.
Any help would be appreciated
Thanks for your help
kgerry
Platinum - Posts: 3,455
Posted: November 03, 2009 at 11:17 AM / IP Logged
are you into menu 3?   item 1 i think?     these units are a real PITA to program without a Bitwriter.....
Kevin Gerry
MECP First Class Installer
Owner/Installer
Classic Car Audio
since 1979
wgrassie
Member - Posts: 8
Posted: November 03, 2009 at 1:16 PM / IP Logged
The trouble I am having is accessing menu 3 to change from Manual to Automatic.
Any ideas on how I can get into menu 3
Thanks for the reply
t&t tech
Platinum - Posts: 2,622
Posted: November 03, 2009 at 6:35 PM / IP Logged
Is your door trigger wire connected? It really is simple to program, but everything must be functional first!
syl20rochon
Copper - Posts: 298
Posted: November 04, 2009 at 5:54 PM / IP Logged
Door pins need to be connected cause the brain needs to see the door open, then turn ignition on the back off, press the switch until you hear 3 chirps, then release the button then press again and hold, you'll hear 1 chirp...while holding down the switch, press the unlock button on the remote, you'll hear 2 chirps that confirms automatic mode...release the switch and wait 5 to 15 seconds until you hear a long chirp, it mean that you have exited the program mode.  You're done.  Good luck.
Sylvain Rochon
MECP security specialist
Tech support for remote starters
26 Years of experience counts
I'm here to help.
wgrassie
Member - Posts: 8
Posted: November 04, 2009 at 8:25 PM / IP Logged
Thanks for the information
I will work through your instructions and let you know how it works out.
Thanks again
wgrassie
Member - Posts: 8
Posted: November 04, 2009 at 8:26 PM / IP Logged
Thanks for helping out- will check the door trigger
wgrassie
Member - Posts: 8
Posted: November 06, 2009 at 2:19 PM / IP Logged
I verified the wiring and worked through your instructions.
I was able to enter the programming mode and switch to automatic Transmission from the default of Manual- easy to program once you get have the  steps to follow.
Remote start will still not engage- Any ideas?
kgerry
Posted: November 06, 2009 at 4:06 PM / IP Logged
did you ground the NSS wire?  do you have the toggle switch plugged in?  both are required to allow R/S to engage.....
does it try to start? if not, how many light flashes do you get?
Kevin Gerry
Owner/Installer
Classic Car Audio
since 1979
wgrassie
Member - Posts: 8
Posted: November 09, 2009 at 9:37 AM / IP Logged
  • When I engage the Remote Start function, I get 1 Parking Light Flash
  • After trying to Remote Start- I tried to start the car with the key,
  •  the car will not start until I toggle the Remote Start switch to the off position.
Any thoughts?
