2005 mazda tribute wire diagram?
kobyt
Member - Posts: 7
Posted: November 07, 2009 at 2:29 PM / IP Logged
I require the alarm remote start wire diagram for a 2005 Mazda Tribute, thanks.
Posted: November 08, 2009 at 2:35 AM / IP Logged
Before posting, you should look to the vehicle wiring on this site. There's a very comprehensive listing for the 04 Tribute. If the body shape is the same, then the wiring should be. Use it as a crib sheet or playbook and test everything.
Platinum - Posts: 13,725
Posted: November 08, 2009 at 5:32 AM / IP Logged
2005 mazda tribute wire diagram? - Last Post -- posted image.BatteryRED (10A)(+)IGNITION SWITCH HARNESS2005 mazda tribute wire diagram? - Last Post -- posted image.
2005 mazda tribute wire diagram? - Last Post -- posted image.Ignition 1LIGHT GREEN/ PURPLE(+)IGNITION SWITCH HARNESS
2005 mazda tribute wire diagram? - Last Post -- posted image.Starter 1TAN/LIGHT BLUE(+)IGNITION SWITCH HARNESS
2005 mazda tribute wire diagram? - Last Post -- posted image.All Door TriggerPINK(-)DRIVER KICK
2005 mazda tribute wire diagram? - Last Post -- posted image.Domelight SuperPINK(-)DRIVER KICK
2005 mazda tribute wire diagram? - Last Post -- posted image.LF LatchLIGHT GREEN/ BLACK(-)PIN 21 ON 32 CONNECTOR ON SJB MODULE CONNECTOR D
2005 mazda tribute wire diagram? - Last Post -- posted image.RF LatchDARK BLUE
2005 mazda tribute wire diagram? - Last Post -- posted image.LR LatchVIOLET/LIGHT GREEN
2005 mazda tribute wire diagram? - Last Post -- posted image.RR LatchPINK/BLUE
2005 mazda tribute wire diagram? - Last Post -- posted image.Trunk TriggerCOMMON WITH DOORS
2005 mazda tribute wire diagram? - Last Post -- posted image.Hood TriggerPURPLE / ORANGE(-)PIN SWITCH UNDER HOOD
2005 mazda tribute wire diagram? - Last Post -- posted image.Alarm DisarmDARK BLUE/LIGHT GREEN(-)DRIVER KICK
2005 mazda tribute wire diagram? - Last Post -- posted image.Alarm ArmWHITE/ VIOLET(-)DRIVER KICK
2005 mazda tribute wire diagram? - Last Post -- posted image.Parking LightsBROWN(+)DRIVERS KICK
2005 mazda tribute wire diagram? - Last Post -- posted image.Low Crr Pk LightsWHITE/ BLACK(-)LIGHT SWITCH
Get power from the battery.
Posted: November 08, 2009 at 10:47 AM / IP Logged
Just to make a point Tommy listed this lot for the 04 in much greater detail. Including the locks being 1 wire multiplex via a 1kr.
