04 jetta, viper 5901
05gt
Silver - Posts: 628
Posted: November 13, 2009 at 1:51 PM / IP Logged
HI I have one quick question regarding the clutch bypass on this car
it says    To bypass the clutch , with a relay program for starter, shorting out the BROWN / White and RED / Black together, will this relay diagram be correct
pin 87 (to one of the clutch wires), pin 30 (to the other clutch wire),  pin 85 (to Ground when running status),  pin 86 (12 volts)
thanks for the help
Mike
wblakes
Copper - Posts: 202
Posted: November 13, 2009 at 3:30 PM / IP Logged
instead of using the "ground when running status output" you should just use the negative starter output to bypass the clutch. that way the clutch is only bypass when the car is starting and not bypassed the whole time you remote start the car.
05gt
Silver - Posts: 628
Posted: November 13, 2009 at 5:35 PM / IP Logged
okay will do, thanks for the help
05gt
Silver - Posts: 628
Posted: November 13, 2009 at 7:32 PM / IP Logged
okay so, I am workign on a 2004 jetta, i am installing a viper 5901 and the idatalink ads-al-ca module
doorpin, trunkpin, trunk release, and foot brake work through the data connection, but the lock and unlock feature do not work, I find this wierd because usually it is the other way around, the bypass programmed correctly so I am kind puzzled by this
anyone have any suggestions
Mike
05gt
Silver - Posts: 628
Posted: November 13, 2009 at 10:32 PM / IP Logged
anyone run into this issue before?
Mike
05gt
Silver - Posts: 628
Posted: November 16, 2009 at 10:05 PM / IP Logged
anyone have any info on this
Mike
Platinum - Posts: 12,488
Posted: November 18, 2009 at 8:05 AM / IP Logged
What cable are you using for the D2D ? or are you using W2W ?
05gt
Silver - Posts: 628
Posted: November 18, 2009 at 3:42 PM / IP Logged
I am using it in D2D and it is the cable that is made to connect DEI products to the idatalink bypasses
