box build confusion
pcana11
Copper - Posts: 116
Posted: November 15, 2009 at 8:07 AM / IP Logged
I have a 12 w6 and im going to build a ported box. But on the JL site it recomends a 29" port but on the calculator on here it recomends a 20" port. Both tuned at 32 Hz. Can anybody recomend one or the other. Please
DYohn
Platinum - Posts: 10,741
Posted: November 15, 2009 at 8:53 AM / IP Logged
In what size enclosure?
pcana11
Copper - Posts: 116
Posted: November 15, 2009 at 7:29 PM / IP Logged
its going to be around 1.75 cubic feet once the brace and port are installed
ianarian
Copper - Posts: 516
Posted: November 15, 2009 at 10:26 PM / IP Logged
If you follow the JL specs, you really cant go wrong. In all actuality, understanding the changes in sound that port dimensions can alter, may help decide which route to take. Port area I usually adhere to, but the length I design/build for the ability to modify if I hear the need.
This is what I do for FUN!
pcana11
Copper - Posts: 116
Posted: November 16, 2009 at 6:05 AM / IP Logged
so what your saying is that if i build this to the jl specs and dont like the way it sounds i can always trim some off but if i build it to the specs from the calculator then i will have to redo the port?
DYohn
Posted: November 16, 2009 at 9:58 AM / IP Logged
The length of the port is dependent on the net volume of the enclosure, the desired tuning frequency and the area of the port opening.  What size port is JL recommending?  The calculator on this site is accurate, assuming you enter accurate information.
pcana11
Copper - Posts: 116
Posted: November 16, 2009 at 8:11 PM / IP Logged
the box is around 1.75 after bracing. the box is from their recomendations as is port. 1.5"x12.5"x29" tuned to around 32.2. the site here is recomending it to be around 20" instead of 29" in deep
Monday, April 27, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
