2007 silverado duramax
jkyliej
Copper - Posts: 101
Posted: November 18, 2009 at 10:50 AM / IP Logged
All,
I've got to do a remote start on a 2007 Silverado Duramax soon and I'll be using a Compustar / iDatalink combo.  I pulled up quite a bit of info searching through the database here but still have a couple of questions.
What color and where is the wait to start wire for the glow plugs?
I see mention of a second starter information only wire and another post said see attached wiring diagram for starter wiring (no wiring diagram attached).  Question is do I need to worry about this second starter wire with a module like the ADS-AL CA?
As always thanks.
jkj
Platinum - Posts: 12,488
Posted: November 18, 2009 at 9:26 PM / IP Logged
Program in the start delay option of the remote starter and for this truck have it set to 8 -10 seconds.
jkyliej
Copper - Posts: 101
Posted: November 19, 2009 at 2:54 PM / IP Logged
Thanks Jeff!
jkj
jkyliej
Copper - Posts: 101
Posted: November 20, 2009 at 12:19 PM / IP Logged
Jeff,
Do you have the starter wiring diagram referenced in this post I pasted below?
GMC 2007 Sierra 4DR Pickup
(Remote Start / Security / GPS)
2007 silverado duramax - Last Post -- posted image. Remote start / security / GPS
 Wire/Function Colour Location/Description Polarity
 PASSIVE ANTI-THEFT YES TRANSPONDER   SEE NOTES
 12 VOLTS RED / white (x3) In black plug on BCM to left of steering column   +
 IGNITION Pink Ignition switch harness   +
 ACCESSORY Yellow Ignition switch harness   +
 STARTER Pink/black (1290-ohms) Ignition switch harness   mux
 Follow the provided diagram for correct wiring of the starter wire for remote start.
jkj
Mike M2
Platinum - Posts: 2,652
Posted: November 20, 2009 at 6:43 PM / IP Logged
If you are using an Idatalink module you don't connect the starter Mux wire. The module does this for you. Only connect igntion and accessory at the keyswitch....
Mike M2
Tech Manager
CS Dealer Services
Posted: November 21, 2009 at 7:17 AM / IP Logged
Seeing that this is a new generation Passlock where the vehicle will crank when it sees the ACC drop out, connect the ALCA using the Type 3 diagram. This uses more power when the vehicle sits, but if it's a daily driver you won't have a problem about a dead battery. Type 3 also does't require an induction ring for the PK3+ bypass.
jkyliej
Copper - Posts: 101
Posted: November 21, 2009 at 9:43 AM / IP Logged
Jeff,
Unfortunatley I was planning to go with install #2.  Customer states this is not his daily driver.  I ordered an ADS RNG GM3 yesterday.
jkj
