2009 ford escape
slowjoe6969
Posted: November 23, 2009 at 1:35 PM / IP Logged
I am Installing a Remote Starter in in a 2009 ford Escape. I have found the wiring diagram is the same as the 2008, but there is no tach wire listed? anyone be able to help with this?
Platinum - Posts: 12,488
Posted: November 23, 2009 at 3:56 PM / IP Logged
Go to the injector or coil for this vehicle. Remove the engine cover and find the two wires at each injector and use the wire that is NOT common between the injectors.
carstereoguy
Posted: January 04, 2010 at 9:27 PM / IP Logged
how about the 12 volt supply and pk lights for a 2008 escape
Posted: January 05, 2010 at 7:19 AM / IP Logged
12 volt you need to go to the battery and PL (+)  PURPLE / WHITE Fuse box (passenger side of center console)
mobiletint
Member - Posts: 47
Posted: January 05, 2010 at 8:56 PM / IP Logged
That parking light wire sucks to get at too!
Car starts itself if you just cycle the ignition... I set these up for a 1.5 sec blind crank, works great.
