05 mazda 3
pitoaudiovisual
Copper - Posts: 388
Posted: December 28, 2009 at 4:16 PM / IP Logged
does anyone have paperwork for an 05 Mazda 3. thank u in advance
Confidence is the key to any project!!
tedmond
Gold - Posts: 4,610
Posted: December 28, 2009 at 6:28 PM / IP Logged
Security
 WIRE  COLOR  POLARITY  LOCATION
 Battery  BLACK/ RED  (+)  IGNITION SWITCH HARNESS
 Ignition 1  GREEN/ YELLOW  (+)  IGNITION SWITCH HARNESS
 Starter 1  GRAY/BLACK  (+)  IGNITION SWITCH HARNESS
 All Door Trigger  BLACK/ BLUE  (-)  AT MODULE NEAR GLOVEBOX TO LEFT OF PASSENGER FOOTWELL
   PIN - U, PLUG #5
 Domelight Super  BLACK/ BLUE  (-)  AT MODULE NEAR GLOVEBOX TO LEFT OF PASSENGER FOOTWELL
   PIN - U, PLUG #5
 Trunk Trigger  BLACK/ RED  (-)  AT MODULE NEAR GLOVEBOX TO LEFT OF PASSENGER FOOTWELL
   PIN - Z, PLUG #6
 Hood Trigger  BLACK / YELLOW  (-)  AT MODULE NEAR GLOVEBOX TO LEFT OF PASSENGER FOOTWELL
   PIN - Y, PLUG #2
 Parking Lights  BLACK/ WHITE  (-)  AT VEHICLE LIGHT SWITCH HARNESS
Remote Start
 Ignition 2  PINK / YELLOW  (+)  IGNITION SWITCH HARNESS
 Accessory 1  YELLOW  (+)  IGNITION SWITCH HARNESS
 Anti-Theft Type  UNIVERSAL IMMOBILIZER
 Anti-Theft Descript  THE KEY SENDS AN RF SIGNAL TO THE BCM MODULE THROUGH AN ANTENNA LOCATED AROUND THE IGNITION CYLINDER
 Crankshaft Sensor  BROWN  (-)  AT PCM MODULE ON FIREWALL UNDER HOOD
   PIN - 2Z
 Camshaft Sensor  BLACK/ WHITE  (-)  AT PCM MODULE ON FIREWALL UNDER HOOD
   PIN - 2V
 Speed Sense  WHITE/ RED  (-)  AT PCM MODULE ON FIREWALL UNDER HOOD
   PIN - 1J
 Brake Lights  RED / WHITE  (+)  AT SWITCH ABOVE PEDAL
 Reverse Lights  GREEN/ BLACK  (+)  BROWN PLUG BEHIND GLOVEBOX
   MAY ALSO BE GREEN/ ORANGE
 Horn  BLACK  (-)  IGNITION SWITCH HARNESS
 Anti Theft RX  GREEN/ RED  (+)  IGNITION SWITCH HARNESS
 Anti Theft TX  BLACK / YELLOW  (-)  IGNITION SWITCH HARNESS
Doorlocks/Windows
 Power Unlock  GREEN/ RED  (-)  DRIVERS KICK
   PIN - T, PLUG #6 MUST USE A RESISTOR FOR INTEGRATION
 PowerLock  GREEN/ RED  (-)  DRIVERS KICK
Ted
Compustar Expert
Posted: December 29, 2009 at 3:08 AM / IP Logged
I was just looking at this post and Ted's reply. The wiring is uncannily close to that year's Euro Focus which isn't too surprising because they are the same car!
Two points:-
a) I thought it had a second ACC, yellow/black.
b) When the job is done, leave it for a couple of hours. See if the door or trunk contacts trigger the alarm when the car is just standing there. It's a "go to sleep" processor problem, this is the cure. Blocking diode on the + side of all dome and trunk lights, 1N4004, band towards light bulb.
pitoaudiovisual
Copper - Posts: 388
Posted: December 30, 2009 at 12:22 PM / IP Logged
thanks but im just doing a remote starter without alarm so i might not have to worry about the dome light or trunk light but thanks anyways for all the help
05gt
Silver - Posts: 628
Posted: December 30, 2009 at 2:28 PM / IP Logged
If this mazda is a manual car, then yes you will have to worry about it, you will need to monitor all doors
