no 2 way feedback? 580 4202p
thirtypackjack
Posted: January 10, 2010 at 12:10 PM / IP Logged
Just got a Python 580 (4202P). Both remotes can lock, unlock, start, stop, pit stop, etc. Only issue is the 2 way remote never gets feedback. Only getting out of range error. Any thoughts?
Thanks,
ThirtyPackJack
t&t tech
Platinum - Posts: 2,622
Posted: January 10, 2010 at 1:47 PM / IP Logged
Try re-programming the remotes if it fails, diconnect power from the unit for a couple minutes and then try!
Thack79
Silver - Posts: 526
Posted: January 11, 2010 at 2:40 PM / IP Logged
you may have a deffective/wrong antenna. had the same issue with a 2way avital 5303
t&t tech
Posted: January 11, 2010 at 5:24 PM / IP Logged
Or as thack said!
nitroxdm
Posted: January 11, 2010 at 5:47 PM / IP Logged
Do you have just the one unit?
I have two cars that both have a DEI Matrix 3.2 installed. If there in the same area I have the same issue.
Once they are separated there isn't an issue.
thirtypackjack
Posted: January 12, 2010 at 6:26 AM / IP Logged
Thanks for all the responses! I tried reprogramming the remotes all seems fine except the 2way never provides the confirmation chirp. I'm thinking its a hardware problem now....but I'll try rebooting
Only have one car.
Thanks,
ThirtyPackJack
thirtypackjack
Posted: January 12, 2010 at 9:14 PM / IP Logged
Tried rebooting and reprogramming, same result - no confirmation chirp. My first one of these - anyone have any idea if these are problematic? If so what part is most likely the cause?
Thanks,
ThirtyPackJack
Thack79
Silver - Posts: 526
Posted: January 13, 2010 at 8:04 AM / IP Logged
switch the antenna with another one. i had the EXACT same problem before however the customer didnt really care, as long as it worked. Believe the antenna is a 548t i believe and i had an older one (same model number and everything) and it was doing the same thing you are describing.
