no hole in h3 door for new wires?
ozofoe
Member - Posts: 15
Posted: January 11, 2010 at 11:19 AM / IP Logged
2006 H3 Hummer: I'm trying to install a 530t window module in the driver's kick panel, and run wires into door.
The lock and window wires break via a wire harness in the door jam. This does not leave me a rubber grommet to make a larger hole, or a new hole to run the five new wires per window (RF, LF). I could drill a new hole in the door frame, but there might be an easier way.
This forum is knowledgeable and experienced so someone might have seen this on other GM vehicles.
chev104275
Gold - Posts: 1,436
Posted: January 11, 2010 at 4:03 PM / IP Logged
is there i hard connector in the jamb ?    if there is you can go through an open cavity in the connector
KarTuneMan
Platinum - Posts: 7,056
Posted: January 12, 2010 at 10:53 AM / IP Logged
ozofoe
Member - Posts: 15
Posted: January 12, 2010 at 4:26 PM / IP Logged
Thanks guys. The pics in the link made it very clear what you're both saying.
