idatalink vs omegalink
luvs2div
Member - Posts: 21
Posted: January 21, 2010 at 12:36 PM / IP Logged
Are these two actually compatible?  Can you D2D an Idatalink to an Excaliber/Omega remote start/alarm?  Use an Omegalink transponder ring on an Idatalink module?  I get modules from 2 different sources.  One always has the rings and the other always has the modules.  Do they interchange?
thunderplains
Member - Posts: 44
Posted: January 21, 2010 at 12:37 PM / IP Logged
You can also check over at www.12voltdata.com, which is Idatalinks forum, you might find more information there.
Mike M2
Platinum - Posts: 2,652
Posted: January 21, 2010 at 2:18 PM / IP Logged
Omegalink and Flashlogic products are just Idatalink units repackaged. Totally interchangable....
Mike M2
Tech Manager
CS Dealer Services
kickyride
Copper - Posts: 100
Posted: January 21, 2010 at 4:18 PM / IP Logged
They are interchangeable. Just pay attention to the data port protocol if you want to use it D2D. Also, each differing brand has different connectors for the data port so watch out for that too. Some CAN be used on others that sort-of fit. If you go wire to wire, there'll def be no problem.
Mike
Mike
Sales/Tech Support - KICKYRIDEoCOM mobile electronics
MECP 1st class-Security Specialist
luvs2div
Member - Posts: 21
Posted: February 01, 2010 at 11:31 AM / IP Logged
Thank you all....Love this site!!!!
Monday, May 4, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
