valet 562t, 98 dodge dak wont start
redmister
Posted: January 24, 2010 at 7:40 AM / IP Logged
I have a 98 Dakota. It has, from the factory, a door lock/panic remote. The Valet, in my truck, does not have that (doorlock/panic) option. Anyway,
The truck wouldn't start (as if it were flooded) an when I was turning it over, with the key, the vehicle just shut off completely. I have plenty of power but it seems like a bad ground, but that isn't the problem. There is a continuous ticking sound coming from the glove box area. The interior lights wont come on, no power to the power windows or door locks... Is there a way to remove the valet 562t from my truck, successfully? If so, how???
"What was I thinkin'!?"
Thack79
Silver - Posts: 526
Posted: January 24, 2010 at 9:45 AM / IP Logged
remove everything you connected. check your main fuses.  if the car wont start, ticking, and etc  you may be over your head (judging by this being your first post) and just take it to a dealer.
Chris Luongo
Platinum - Posts: 3,746
Posted: January 24, 2010 at 8:35 PM / IP Logged
Unless you have a good reason to suspect that the remote starter is somehow causing the problem, you might just be wasting your time, and then you won't have any remote starter anymore either.
Have you already tried the basic stuff? Jump start, maybe remove battery and bring it to a parts store. Most of them test and charge batteries for free.
redmister
Posted: January 25, 2010 at 6:20 AM / IP Logged
I accidentally found the problem.
The starter, itself, had a bad ground.
Thanks!
Monday, May 4, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
