getting vehicle started info
chuckycharms
Posted: January 29, 2010 at 10:19 AM / IP Logged
Hey all,
I have a scytec galaxy 2000 installed in my 05 Nissan Titan. Im just tinkering around with putting a linux box on the truck to do some 'random' things. I have a sensor on my linux box that waits for a voltage spike to signal a program to initiate.
What I would like to know is what is the best way to know when a car has been started, and be able to feed that into this sensor. Any thoughts would be awesome!
oldspark
Gold - Posts: 4,913
Posted: January 31, 2010 at 2:54 AM / IP Logged
Charge lamp circuit. Goes to +12V when charging.
chuckycharms
Posted: February 16, 2010 at 12:03 PM / IP Logged
Hey Thanks!!
Would you have any suggestions as to a way to find this on most vehicles?
oldspark
Gold - Posts: 4,913
Posted: February 16, 2010 at 3:40 PM / IP Logged
The D+ or L wire from the voltage regulator - ie, alternator.
It should go to the ground of the dash's charge bulb - maybe via a diode, and maybe via other diodes to other dash lamps (eg - brake fault) (all diodes being in the dash) - or it could power a relay etc.
Hence stick with the alternator end...
Thursday, December 25, 2025 • Copyright © 1999-2025 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
