2x 2ohm dual voice coil subs wiring
balz7
Posted: February 24, 2010 at 12:13 AM / IP Logged
I just bought 2x Kicker SoloClassic s12c 12" subs. they are 2ohm dual voice coil. I am running a Kicker KX1200.1 amp, that is 1200 watts rms at 1ohm. I found diagrams on this website that shows how I can wire it up, my problem is its giving me the option of running at 0.5ohms, or 2 ohms. my amp can't handle the 0.5ohms and I'm thinking that running it at 2 ohms won't be giving them enough power because the amp will be running at half power. Any ideas?
Anthony
Platinum - Posts: 13,726
Posted: February 24, 2010 at 12:58 AM / IP Logged
Since you already have the equipment, run the amp into the 2 ohm load and see if it does what you need it to do.  For future reference, it is usually a good idea to buy the right woofers for the amp you have.  Or Vice Versa.
balz7
Posted: February 24, 2010 at 5:52 PM / IP Logged
Thanks thats what i was thinking
hijacking?
Anthony
the12volt
Administrator - Posts: 3,959
Posted: February 24, 2010 at 8:49 PM / IP Logged
Topic moved to correct forum.
2x 2ohm dual voice coil subs wiring - Last Post -- posted image. the12volt • Support the12volt.com
zappo90744
Member - Posts: 16
Posted: March 11, 2010 at 11:10 AM / IP Logged
Yeah, you bought the wrong subs.  Should've gone with dual 4ohm.
Sunday, April 26, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
