new guy, 2010 lacrosse
alarep5
Member - Posts: 28
Posted: March 08, 2010 at 11:28 PM / IP Logged
Hi, new guy here,
Been installing for about 9 years. Astro brand. Have used about every bypass brand.
Work at a GM dealership. Got most of the GM's figured out except the 2010 Lacrosse push to start.
Anybody done one yet, let me know. I have customers waiting. No info  from the r/s techlines yet.
Got the Terrain figured out, let me know if anyone needs info.
OLDSCHOOL - If the wire is there,...use it.
tedmond
Gold - Posts: 4,610
Posted: March 09, 2010 at 5:41 AM / IP Logged
hey, welcome to the12volt.
here is the info i have
Omega - http://www.wiringinstructions.com/v2/wiresprint.asp?recnum=10188&printsubmit=PRINT
Fortin Electronics -
Item  Wire Color  Polarity  Wire Location
 12 Volts  RED / white (30A), red (15A), RED / white (15A)  +  BCM, lt. blue plug, pins 4, 3, and 1
  The BCM (Body Control Module) is under the driver dash.
 Second 12 Volts  RED / white (100A), RED / white (100A)  +  dash fuse box, ring terminals
 Starter  purple (not for remote start)  +  starter or underhood fuse box, black 50 pin plug, pin 5
  On vehicles with push-button start, the push to start wire is lt. GREEN / WHITE (- resistor) at the ignition mode switch, gray 8 pin plug, pin 6 or the BCM, lt. blue plug, pin 17. The BCM (Body Control Module) is under the driver dash.
 Second Starter  pink (without push-button start)  +9.6K ohms  ignition switch or BCM, lt. green plug, pin 15
  The BCM (Body Control Module) is under the driver dash. If interface module is not available, see Tech Doc 1605.
 Ignition  pink (without push-button start)  +  ignition switch or BCM, lt. green plug, pin 6
 Second Ignition  N/A
 Third Ignition  N/A
 Accessory  brown (without push-button start)  +  ignition switch or BCM, lt. green plug, pin 5
 Second Accessory  same as second starter  +6.3K ohms
 Third Accessory  N/A
 Keysense  same as second starter
 Data Bus  pnk (r-code), wht/blk (5V ref)(w/o push-btn start)  mux  ignition switch or BCM, lt. green plug, pins 15 and 22
 Can Bus High  N/A
 Can Bus Low  N/A
 Can Bus Sw  dk. green (low speed GMLAN)  data  data link conn, black 16 pin plug, pin 1 or BCM, lt. blue plug, pin 22
 Power Lock  pink/black  -  BCM, lt. blue plug, pin 19
 Power Unlock  ORANGE / black  -  BCM, lt. blue plug, pin 15
 Lock Motor  gray  5 wire  BCM, pink plug, pin 1
 Driver Unlock Motor  tan  5 wire  BCM, pink plug, pin 4
 Parking Lights (-)  lt. blue  -  BCM, white plug, pin 22
 Parking Lights (+)  purple (L), BROWN / white (R)  +  BCM, black plug, pins 6 and 5
 Hazards  white  -  BCM, lt. blue plug, pin 26
 Turn Signal (Left)  lt. blue/white (F), yellow/black (R)  +  BCM, brown plug, pins 2 and 1
 Turn Signal (Right)  dk. blue/white (F), dk. GREEN / WHITE (R)  +  BCM, black plug, pins 3 and 4
 Headlight  white (also need to trigger parking lights (-))  -  BCM, white plug, pin 16
 AutoLights  dk. green (ground to turn off autolights)  -  BCM, white plug, pin 11
 Reverse Light  lt. green  +  BCM, gray plug, pin 3
 Left Front Door Trigger  gray/black  -  driver window motor, black 7 pin plug, pin 6
 Right Front Door Trigger  tan/white  -  passenger window motor, black 7 pin plug, pin 6
 Left Rear Door Trigger  lt. blue/black  -  left rear window switch, black 8 pin plug, pin 2
 Right Rear Door Trigger  lt. GREEN/ black  -  right rear window switch, black 8 pin plug, pin 2
 Dome Supervision  gray (dome lamps), ORANGE / black (puddle lamps)  +  BCM, gray plug, pins 1 and 8
 Trunk/Hatch Pin  pink/black  -  BCM, pink plug, pin 5
 Rear Glass Pin  N/A
 Hood Pin  pink/black  -  BCM, black plug, pin 24
 Trunk/Hatch Release  gray  -  BCM, pink plug, pin 15
  The BCM (Body Control Module) is under the driver dash. Meter this wire while opening the trunk from the handle on the rear of the vehicle.
 Trunk Release Motor  lt. blue  +  dash fuse box, black 15 pin plug, pin 5
 Fuel Door Release  N/A
 Power Sliding Door (Left)  N/A
 Power Sliding Door (Right)  N/A
 Factory Alarm Arm  arms on lock with door open
 Factory Alarm Disarm  factory remote only
 Disarm No Unlock  Passkey and ignition
 Trunk Alarm Shunt  N/A
 Tachometer  brn, dk. blue, dk. grn, lt. blue, lt. grn, or pur  ac  any fuel injector
 Wait to Start  N/A
 Neutral Safety  N/A
 Clutch Pedal  N/A
 Fuel Pump  pink  +  passenger kick, harness to rear
 Rear Defroster  white  + latched  HVAC Control Module, brown 20 pin plug, pin 19
  The HVAC Control Module is in the center of the dash, behind the HVAC and radio controls.
 Mirror Defroster  same as rear defroster
 Left Front Heated Seat  RED / white and GREEN/ black  +,-  Heated Seat Control Module, black 16 pin plug, pins 3 and 1
  The Heated Seat Control Module is under the driver seat. On vehicles with memory seat, it is at the Memory Seat Module, black 16 pin plug, pins 11 and 6. The Memory Seat Module is under the driver seat.
 Right Front Heated Seat  WHITE/ orange and WHITE/ purple  +,-  Heated Seat Control Module, black 16 pin plug, pins 5 and 2
  The Heated Seat Control Module is under the driver seat. On vehicles with memory seat, it is at the Memory Seat Module, black 16 pin plug, pins 10 and 4. The Memory Seat Module is under the driver seat.
 Speed Sense  lt. green (some models only)  ac  radio, gray 20 pin plug, pin 20
  Also found at the Electronic Brake Control Module, black 38 pin plug, pin 34. The Electronic Brake Control Module is in the left side of the engine compartment, at the strut tower.
 Brake Wire  white  +  BCM, black plug, pin 11
 Parking Brake  (high speed GMLAN)
 Horn Trigger  tan  -  BCM, brown plug, pin 19
 Wipers  gray  +  BCM, black plug, pin 16
 Memory Seat 1  white or GREEN/ YELLOW  - 630 ohms  memory seat switch, black 6 pin plug, pin 6
 Memory Seat 2  same as memory seat 1  - 2K ohms
 Memory Seat 3  N/A
Ted
Compustar Expert
alarep5
Member - Posts: 28
Posted: March 09, 2010 at 8:28 AM / IP Logged
tedmond,
thanks for the info
