remote start alarm 99 durango
jweb2k10
Posted: March 18, 2010 at 8:59 PM / IP Logged
I bought the astra 4000rs-2w1 remote car start this damn thing is pretty confusing. i own a 99 dodge durango with keyless entry i am questionin the use of all of the wires on this product can someone please tell me does it matter what type of relays it takes i bought 2 5 pin relays just something a lil more clear cut cuz this 16pin harness wit the alarm is extensive and id rather learn to do this instead of pay to have it done and my questions still be there. i dont understand wth they have three different wiring schematics for my truck i dont understand this diodes on the door trigger and what type of locks i have a negative trigger lock or postive. i wana set up with the two stage lock system however it isnt a neccessity. a clearer cut diagram and info on types of extras i need to buy would be greatly appreciated
jweb2k10
Platinum - Posts: 13,726
Posted: March 18, 2010 at 9:23 PM / IP Logged
remote start alarm 99 durango - Last Post -- posted image. Battery PINK/BLACK (+) OR RED IGNITION SWITCH HARNESS
remote start alarm 99 durango - Last Post -- posted image. Ignition 1 DARK BLUE (+) IGNITION HARNESS
remote start alarm 99 durango - Last Post -- posted image. Starter 1 YELLOW (+) IGNITION HARNESS
remote start alarm 99 durango - Last Post -- posted image. All Door Trigger YELLOW (-) HEADLIGHT SWITCH OR COURTESY LIGHT SEE N
remote start alarm 99 durango - Last Post -- posted image. Trunk Trigger TAN/BLACK (-) 16 PIN CONN BELOW FUSE BOX
remote start alarm 99 durango - Last Post -- posted image. Alarm Disarm LIGHT GREEN/ ORANGE (-) 18 PIN CONN DR.KICK POS 10 SAME WIRE ARM
remote start alarm 99 durango - Last Post -- posted image. Alarm Arm W/LOCKS
remote start alarm 99 durango - Last Post -- posted image. Parking Lights BLACK / YELLOW (+) 18 PIN CONN POS 1 HEADLIGHT SWITCH
Posted: March 18, 2010 at 9:24 PM / IP Logged
remote start alarm 99 durango - Last Post -- posted image. Ignition 2 BLACK/ ORANGE (+) IGNITION HARNESS (HEAT/A.C.)
remote start alarm 99 durango - Last Post -- posted image. Anti-Theft Descript NONE
remote start alarm 99 durango - Last Post -- posted image. Key Sense LIGHT BLUE (-) IGNITION SWITCH HARNESS
remote start alarm 99 durango - Last Post -- posted image. Neutral Safety YELLOW (-) LOWER LEFT OF DASH 16 PIN CONN POS 3
remote start alarm 99 durango - Last Post -- posted image. Tachometer BLACK/ GRAY (AC) COIL PASS FRT ENG OR PCM FRT WASH FLUID
remote start alarm 99 durango - Last Post -- posted image. Speed Sense WHITE/ ORANGE (AC) PIN 27 AT ECM PASS. SIDE FRT. FENDER
remote start alarm 99 durango - Last Post -- posted image. Brake Lights WHITE/ TAN (+) AT BRAKE SWITCH
remote start alarm 99 durango - Last Post -- posted image. Reverse Lights VIOLET/BLACK (+) DRIV SIDE OF TRANS
remote start alarm 99 durango - Last Post -- posted image. Horn BLACK/ RED (-) STEERING COLUMN HARNESS
Posted: March 18, 2010 at 9:26 PM / IP Logged
If your vehicle has factory keyless, the lock type is positive pulse.  The wire colors are listed below
remote start alarm 99 durango - Last Post -- posted image. Power Unlock PINK/VIOLET (REV) POS 13 POS(+)IF KEYLESS: REV IF NOT KEYL remote start alarm 99 durango - Last Post -- posted image.
remote start alarm 99 durango - Last Post -- posted image. PowerLock ORANGE / VIOLET (REV) 18 PIN CONN POS 4 MODULE RIGHT OF DASH
blanx218
Silver - Posts: 654
Posted: March 18, 2010 at 9:45 PM / IP Logged
as long as the relays are rated 30 amps or higher they will be fine. heres a little info for your durango.
Lock - ORANGE / purple (+) blue plug in DKP
Unlock - pink/purple (+) same plug as lock
LF door trigger - BLACK/ blue (-) black plug in DKP
All other doors - tan/red (-) same plug
unless your system has alternating (+/-) locks use the (-) outputs to trigger the relays and convert the negative to a positive. if you want progressive locks you would have to use the motor wires which are 5wire.
use 2 diodes on each of the door trigger wires to isolate them
