1997 Ford Econoline E-250 VSS
2ndlife
Member - Posts: 15
Posted: April 26, 2010 at 7:24 PM / IP Logged
I am looking for the VSS wire on a 1997 Ford Econoline E-250. So far information from this forum seem to indicate that it is at the PCM at driver side firewall and it is gray/black in color.
I think I've found it but just want to make sure if I am looking at the right place. I have two pictures and in both it is difficult to see clearly but in person the wire pointed to is colored gray/black. They are the same wire with pictures taken at different angles. Can anybody confirm for me if I have found the right wire?
Thanks.
1997 Ford Econoline E-250 VSS - Last Post -- posted image.
Ween
Platinum - Posts: 1,368
Posted: April 26, 2010 at 9:54 PM / IP Logged
hi,
it's also at the instrument cluster and cruise control servo... same color
m
2ndlife
Member - Posts: 15
Posted: April 28, 2010 at 3:44 AM / IP Logged
Thanks. I looked behind the instrument cluster and did find a
gray/black wire there also. This makes it even easier since I won't need to fish a wire from under the hood.
Just a rookie question: On any car, for example in my case a gray/black wire, is it safe to assume the wire/wires with a certain color is for sure assigned to that purpose? (In this case gray/black is the VSS wire as per the given data.) So another words if I find a gray/black wire anywhere in the car, it must be the VSS wire, right?
Ween
Posted: April 28, 2010 at 6:59 AM / IP Logged
not any car, no.  but ford has used that color for years.  changed when they used data bus for information transfer.  simplifies wiring at the cluster etc.
