moonroof relay, 93 civic
daygobaker
Member - Posts: 17
Posted: May 06, 2010 at 9:10 PM / IP Logged
okay....change the switch or the relays...which one is messing up....it will stop intermitently...., which stops the motor...the relay or the switch...you say change the switch, so im thinking the switch has a circuit breaker....and the relays just feed power?
Posted: May 07, 2010 at 12:48 AM / IP Logged
Ignition on, ground each relay in turn,see how it moves, if no problems you're either imagining a non-existent problem or the switch is at fault. The nearest thing to a circuit breaker is called a fuse. This thread is starting to get silly.
daygobaker
Member - Posts: 17
Posted: May 07, 2010 at 10:36 AM / IP Logged
okay....you know how a power window stops (the motor)...when its fully closed or opened....thats how i want my sunroof to work...i dont want to burn the motor out....i understand how a relay works, i was just wondering if there is a different type of relay that stop feeding as soon as the current starts to get high (as if the motor is burning up from not being able to move the glass)....i can think of a circuit breaker....but i was wondering if what part of the system is not making it break power....cause its an intermittent problem......sometimes it stops feed power, sometimes it doesn't....what im asking is what is causing that problem.... basically is my relay messed up, my switch, or some kind of mechanism on the motor?
Posted: May 07, 2010 at 2:49 PM / IP Logged
If you want a circuit breaker, use a 529t (thermal breaker) otherwise test as I suggested, I'm 99% sure it's the switch. Failing that the motor.
