what would the ohms be?
romitio222
Posted: May 20, 2010 at 1:25 AM / IP Logged
image is a quick example of how these subwoofers are wired, not sure what ohm load would be on amp.
what would the ohms be? - Last Post -- posted image.
Platinum - Posts: 13,726
Posted: May 20, 2010 at 6:23 AM / IP Logged
If the negative non bridged terminal is broken, both of the non bridged terminals are connected together.  Simply connect the left negative wire to the right positive screw along with the right positive speaker wire.
The diagram you posted will be a 4 ohm load.  4 ohm mono is the same exact electrical load as a 2 ohm stereo load.
Saturday, April 25, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
