avic x910bt, 2008 vw rabbit
hcsauto
Posted: May 22, 2010 at 2:27 PM / IP Logged
I have a 2008 VW Rabbit.  I am installing a Pioneer Avic-X910BT.  I would like to know the colors of the the Speed input wire, Reverse light wire and the Parking brake wire.  Your assistance is greatly appreciated.
topperz7
Member - Posts: 14
Posted: May 24, 2010 at 1:48 AM / IP Logged
Speed sense is a BROWN wire locate at the ABS MODULE under your hood
Reverse light wire is BLACK /w BLUE stripe in driver kick panel harness to rear of car can also be found at the fuse box under your dash or all else fails at your reverse light bulb.  You only need this wire if you are hooking up reverse camera otherwise forget about it
Your Parking brake wire is BROWN / w YELLOW stripe at the base of your parking brake
hcsauto
Posted: May 24, 2010 at 6:57 AM / IP Logged
Thanks.  I will give you a call today about the parking brake solution.
