system out after hitting a speed bump
spmpdr
Copper - Posts: 456
Posted: June 05, 2010 at 8:22 PM / IP Logged
Today i was pulling out of the parking lot at my work and just turned on my stereo ,everything was fine system played like normal then i went over a speed bump and everything but the h/u lost power!!! Where do i start trouble shooting this I looked over all the power and ground wires to the amps and they are fine.
heres my eqiupment:
h/u: kenwood kdc x993
arc audio eqx/idx crossover and equalizer
re audio 1600.2v2 sub amp
re audio 1600.4v2 mids amp
ppi275 tweets amp
(2) re audio sr 12's
(2) xtant 4" mids
(2) xtant 1.5" tweets
(2) mpyre 6.5" mids
everything is ran at 4ohms,no protection lights are on and there is no power to anything but the h/u
-A vision without a plan is just a hallucination-
Platinum - Posts: 13,726
Posted: June 05, 2010 at 8:46 PM / IP Logged
If you have one power wire that powers both amps, I would look at that wire and it's fuses.   Check the remote wire too.
You may need to use a volt meter to determine what is missing from the amps.
nismo542
Copper - Posts: 62
Posted: June 05, 2010 at 9:41 PM / IP Logged
i would start at the battery and check all fuses.  also check your ground an make sure it is still connected to the chassis.
spmpdr
Copper - Posts: 456
Posted: June 06, 2010 at 9:16 AM / IP Logged
Its actually three amps, There is one power wire that is daisy chained I checkd the power and grounds visually but not with a dmm.Im thinking since the h/u has power but everything else doesnt that it has to be the remote wire shorted or grounded somewhere.I do have a dmm but im not sure i know how to use it correctly,is there a tutorial on using one anywhere?I dont know the settings that the dmm needs to be on or what the dmm should be reading.
Posted: June 06, 2010 at 9:50 AM / IP Logged
Can you find the setting for checking DC Voltage?  It iwll either read DCV, or V with a solid line above a dashed line.  If it has multiple choices under that setting, set it to 20.  Touch and hold the black lead to the ground terminal of your battery, then touch the red lead to the positive terminal of your battery, it should read between 11.5 and 12.5 without the engine running.
spmpdr
Copper - Posts: 456
Posted: June 06, 2010 at 10:39 AM / IP Logged
I think i found the problem ,to test the remote wire I jumped it from a hot line and everything started working againsystem out after hitting a speed bump - Last Post -- posted image.,so what is the proper way to run a remote wire for this setup?Right now they are all daisy chained together off the h/u i believe.Thanks for the info on how to use the dmm by the way "i am "
spmpdr
Copper - Posts: 456
Posted: June 06, 2010 at 5:19 PM / IP Logged
Alright so after testing with the dmm at first i got a reading of .40 with the truck on and the system came back on. I put the truck back together and closed my passenger side door and the system went back offf!!! I took the truck back apart and test the remote line again with the truck on and got a reading at the back of the h/u of .10 .Could my h/u be defective or do i need to test something else?I didnt think to locate where the remote wire gets it power source from is it from the h/u or an ignition wire or a 12volt constant or somethiing like an ignition wire .I didnt see anywhere where the line went to something other than one of my stereo components.
bloob
Member - Posts: 20
Posted: June 10, 2010 at 6:08 PM / IP Logged
your remote wire should be connected to the factory car /HU harness. it's usually solid blue if i recall.
things to look at:
possible your remote wire got bared somewhere in between your HU and your amps and now it's grounding out. this somes to mind because you mentioned when you shut your passenger door the system went off again. it's possible your remote wire runs under the door trim along the passenger side?
also possible you need to check your rca's. they sometimes slip free from over used ports on amps.
Saturday, April 25, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
