buzz noise
gauge010
Member - Posts: 19
Posted: June 21, 2010 at 2:51 AM / IP Logged
Hey Guys,
Wondering if anyone can help me. Recently installed a system on an E90 BMW. After all that was done, there we 2 types of noise. There was an alternator whine and a buzzing sound when the park light were turned on. I was able to get rid of the alt whine one the right tweeter by rerouting the wires(this was an active setup). The buzzing sound however is still there. Without lights turned on, the system was quiet. Any thoughts on this? The amps were grounded directly to the battery at the back. Could that be the cause? Just a hunch.
Thanks all,
V.
My simple setup on a 2008 Nissan Frontier:
Alpine IVA-W505
Alpine PXA-H100
Audison LRx 6.9
Dynaudio MD 100 (full active)
Dynaudio MW 162 (full active)
Pioneer TS-W258D4 10" shallow mount sub
Platinum - Posts: 13,726
Posted: June 21, 2010 at 6:25 AM / IP Logged
Does the pitch of the noise change when you adjust the brightness of your dash lights?
91stt
Silver - Posts: 564
Posted: June 21, 2010 at 11:00 AM / IP Logged
Do you have aftermarket HID headlights?
This information is provided only as a reference.
All circuits should be verified with a digital multi-meter prior to making any connections.
Posted: June 21, 2010 at 2:04 PM / IP Logged
The noise is there with parking lights.  If the noise changes pitch with the dimming of the dash lights, it is the same as the noise generated by the HID lamps.  There is a pwm power supply to regulate the voltage of the dash lamps.  I had this problem in an 85 Honda CRX, I tried everything to get rid of the noise, never did get rid of the noise.  It was less noticeable with the dash lights at full brightness.
gauge010
Member - Posts: 19
Posted: June 21, 2010 at 2:30 PM / IP Logged
Thanks for the replies guys. The pitch of the noise doesnt change when I havent tried that yet. But yes it does have an aftermarket HID kit. Any more suggestions would be great.
Thanks,
V.
Alpine IVA-W505
Alpine PXA-H100
Audison LRx 6.9
Posted: June 21, 2010 at 6:25 PM / IP Logged
I am confused.
gauge010
Member - Posts: 19
Posted: June 21, 2010 at 11:07 PM / IP Logged
Thanks,
V.
Sorry IAAI...What I meant to say was the pitch of the noise does not change when I dim the dash lights. :)
Alpine IVA-W505
Alpine PXA-H100
Audison LRx 6.9
91stt
Silver - Posts: 564
Posted: June 21, 2010 at 11:17 PM / IP Logged
Disconnect the ballast for you HIDs to see if it makes a difference (do not disconnect the bulbs).
Saturday, April 25, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
