timer relay voltage
ocman
Member - Posts: 20
Posted: June 24, 2010 at 10:46 PM / IP Logged
I've got a small timer circuit, that has an input/output relay rated at 5A @ 220V AC.    I'm going to use this timer to power a 12V DC thermoelectric cooler. I'm wondering if I could run the 12V DC through the existing relay, or do I need another relay?   Thanks
ocman
Member - Posts: 20
Posted: June 24, 2010 at 10:49 PM / IP Logged
timer relay voltage - Last Post -- posted image.
KPierson
Platinum - Posts: 3,527
Posted: June 25, 2010 at 5:33 AM / IP Logged
How much current does your cooler pull? As long as you stay under 5A you won't have a problem.
Kevin Pierson
ocman
Member - Posts: 20
Posted: June 25, 2010 at 10:42 AM / IP Logged
Thanks for the reply Kevin.
The cooler pulls 5A @ 12V DC. I'm guessing I should run the + lead through the relay?
Monday, February 2, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
