amp clipping, shutting off
shije
Posted: July 16, 2010 at 4:44 PM / IP Logged
my setup consists of:
1 Power Acoustik BAMF2000/1D monoblock amplifier
1 Power Acoustik 2ohm DVC MOFO brigded to 1.3ohms
1 VR3 1Farad digital capacitor
All 4guage power/ground cables
ok so my situation is my amp clips/shuts off for split seconds when the volume is turned to about 75%...and also i hear clicking sounds from the amp while the subwoofer is not running... is this because my amp's gain is not set properly?
blt
icearrow6
Copper - Posts: 497
Posted: July 16, 2010 at 6:32 PM / IP Logged
DYohn
Platinum - Posts: 10,741
Posted: July 16, 2010 at 7:14 PM / IP Logged
This is impossible.  If it's a DVC 2-ohm speaker, it can be wired for 4-ohms or 1-ohm, but not for 1.3 ohms.
roadshop570
Copper - Posts: 128
Posted: July 16, 2010 at 8:04 PM / IP Logged
Check your voltage from your amp ground, is it mounted and/or are you using spacers under the amp for air flow? Is it in a location where its getting air? Whats your wire size?
Chadillac
Sound Pressure
Silver - Posts: 711
Posted: July 19, 2010 at 10:58 PM / IP Logged
its over loading turn down the gains. check the way you wired your subs the amp may not be able to push it. check your grounds and make sure they are not tied into the seat belt.
Sound Pressure
Friday, April 24, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
