cavalier 2005 wiring diagrams
mike31
Copper - Posts: 75
Posted: July 22, 2010 at 6:02 PM / IP Logged
HI EVERYONE
In regards to wiring diagram of cavalier 2005 specificly trunk release I pulled out the BCM blue plug to locate black WITH WHITE STRIPE WIRE BUT I NOTICED THERE ARE MORE THAN ONE ABOVE MENTIONED WIRE. Could you please help how to locate the exact wire .Thanks a lot mike
Platinum - Posts: 7,828
Posted: July 22, 2010 at 7:49 PM / IP Logged
Should be at pin B4 in that blue plug.  Here is a link to a picture of the plug & wire from Bulldog Security :  http://www.bulldogsecurity.com/diagrams/Images.asp?ImageID=612&link=Bulldog
All else fails, use your Digital Multi-Meter.  Set meter to 20v DC.  Red lead to +12 volts constant.  Black lead to suspect wire.  Press trunk release and look for meter to go to +12v briefly as trunk pops open.
mike31
Copper - Posts: 75
Posted: July 22, 2010 at 9:31 PM / IP Logged
HI
Thanks for the reply if possible can you tell how the plugs are labled.
mike
Posted: July 23, 2010 at 7:35 PM / IP Logged
Its been a while and I didn't take any pictures, sorry.  Car manufactures do that a lot, putting wires with identical colors in the same plug.  If memory serves me, it was fairly straight forward and easy to locate, test and verify.  A Digital Multi-Meter is an indispensible tool in this business...
another-kelly
Silver - Posts: 618
Posted: July 25, 2010 at 11:26 PM / IP Logged
gm's generally label their plugs. look closely at that harness when you pull it out. should have one side labeled "A" and the other "B", then one end starting at "1" and the other "12"
