ford f 150 05 factory stereo
madrigal87
Member - Posts: 22
Posted: August 29, 2010 at 6:22 PM / IP Logged
How can i hook up my amp to my factory stereo. like the remote wire and rca cables on a Ford F-150 2005? Thanks
francisco madrigal
Platinum - Posts: 13,725
Posted: August 29, 2010 at 7:03 PM / IP Logged
You will need a line out converter. Most people connect the remote wire to the accessory wire of the radio.  The amp will be on anytime the ignition switch is in the on or acc position.  If this is not acceptable for you, they do sell line out converters that will give you a remote output.
elpadre
Posted: August 30, 2010 at 1:18 PM / IP Logged
If you allready got the converter best or easy way is just put to 1 speaker, 1st take radio out find those wires blue/white - and ORANGE / green + and put the remote wire to Light GREEN/ YELLOW wire it is the swich wire
Javier sierra
Posted: August 30, 2010 at 2:55 PM / IP Logged
You really need to connect the converter to both channels of your deck.  I know that there is not much difference between left and right low frequency information, but why would you want to have only left or right information getting to your sub.  It is a stereo system.  Stereo meaning 2 separate channels of information.
