remote start issues
fperezii
Posted: September 18, 2010 at 7:27 PM / IP Logged
I have a 1985 Cutlass Supreme, and I am having trouble with the remote start working properly. The car will crank over, but will not start. I understand that some carburator cars are tuff to start. But if I put the key in and turn it forward to the on position,the car will start with no problems when I use the remote start. What could this be? Do I have it wired wrong, I wired it to the starter wire like shown. Please let me know, thanks.
"Turn N Heads" 2009 WEGO Radical Champion
Platinum - Posts: 13,726
Posted: September 18, 2010 at 8:24 PM / IP Logged
WIRE COLOR POLARITY LOCATION remote start issues - Last Post -- posted image.
remote start issues - Last Post -- posted image. Battery RED (+) IGNITION SWITCH HARNESS
remote start issues - Last Post -- posted image. Ignition 1 PINK (+) IGNITION SWITCH HARNESS
remote start issues - Last Post -- posted image. Accessory 1 ORANGE (+) IGNITION SWITCH HARNESS
Posted: September 18, 2010 at 8:25 PM / IP Logged
Using a volt meter verify that there is voltage on the pink wire while under an attempted remote start.
Thack79
Silver - Posts: 526
Posted: September 20, 2010 at 1:45 PM / IP Logged
If you didnt run tach wire, check your voltage timing
kgerry
Platinum - Posts: 3,455
Posted: September 22, 2010 at 6:18 PM / IP Logged
sounds like you didnt power a required IGN wire.......
Kevin Gerry
MECP First Class Installer
Owner/Installer
Classic Car Audio
since 1979
fperezii
Posted: September 24, 2010 at 7:53 AM / IP Logged
Thanks for all the help.
