2011 ram 2500 diesel manual transmission
dieselboy_01
Member - Posts: 13
Posted: November 30, 2010 at 7:22 PM / IP Logged
Guys,
I have a Compustar CM6200S starter with a Blade AL(DL)-CH4 bypass module. And am going to install it on a Ram 2500 diesel with a moanual transmission.
Do I just hook up the starter as per the dierctions for the blade module? Or do I need to hook up some of the hardwire connections as well?
Also is the best set up or should I use the Fortin EVO-CHR module as it just plugs in?
mobiletint
Member - Posts: 47
Posted: December 01, 2010 at 7:29 AM / IP Logged
I used ADS for a couple years and finally made the switch to fortin two weeks ago. Depending on what your working on the Fortin bypasses are 10x better. Id use the EVO CHR before ADS. I pulled a couple ADS pieces out and replaced with Fortin recently.
rjkboyle
Copper - Posts: 97
Posted: December 01, 2010 at 2:14 PM / IP Logged
Just did a 2004 3500 Diesel with a fortin, and was great. Especially if your alarm supports the two way data link. I would say for the fortin, but either way you will have the end result.
