will this amp work?
hitman89x
Member - Posts: 6
Posted: December 12, 2010 at 7:11 PM / IP Logged
Ok i have two 12" boss audio subs rated at 1000 watts rms each and they are 4 ohm DVC.
I want to wire them in a parallel/parallel config. my question is will this amp be good to power them and be safe to not blow them out at 1 ohm load?
http://#/sosev3000d.html
All help appreciated =)
oldspark
Gold - Posts: 4,913
Posted: December 12, 2010 at 7:23 PM / IP Logged
Crikey - this is almost identical to 5000 watt subs except that the EV3000D is only 600W RMS into 4 Ohm.
It's max input is 864W if 60A @ 14.4V.
I'll let others answer the speaker config & matching....
hitman89x
Member - Posts: 6
Posted: December 12, 2010 at 7:39 PM / IP Logged
another thing im a little confused about it being wired at 2 ohm or 1 ohm because the speaker booklet shows that the subs can be wired in 2,4 or 8 ohms not 1 ohm but from looking around ( on here ) at wiring diagrams it shows two dvc 4 ohm subs being 1 ohm will this amp work? - Last Post -- posted image.
is the 2 ohm option for perhaps 1 sub hooked to the amp?
Platinum - Posts: 13,726
Posted: December 12, 2010 at 7:50 PM / IP Logged
Your wiring options with 2 dual 4 ohm coils are 1ohm, 4ohm or 16ohms.  With a lone 4ohm DVC, your options are 2ohm or 8ohm.
hitman89x
Member - Posts: 6
Posted: December 12, 2010 at 7:53 PM / IP Logged
ok thanks for clarifying that.
so what i need is an amp that can push at or just below 2000 watts continously @ 1 ohm, correct?
hitman89x
Member - Posts: 6
Posted: December 12, 2010 at 9:47 PM / IP Logged
ok after looking around a bit i came up with this:
http://www......com/item_24268_Power-Acoustik-CPT1-3200D.html
or this one:
http://www......com/item_17385_Kole-Audio-TRAX1-4000D-TRAX-1-4000D.html
i would much rather go for the power acoustik just because of price but i was wondering what anyones thought is to either of these amps..
hitman89x
Member - Posts: 6
Posted: December 13, 2010 at 1:25 PM / IP Logged
anything?
hitman89x
Member - Posts: 6
Posted: December 13, 2010 at 1:34 PM / IP Logged
ok i just realized those links i put dont work.. will this amp work? - Last Post -- posted image.
so heres the models:
Power acoustik: CPT1-3200D
Power acoustik: OVN1-4000D
Kole Audio: TRAX1-4000D
sorry for the messed up links...
Thursday, April 23, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
