python 1401 with smartstart errors
bobekdj
Posted: December 24, 2010 at 9:22 PM / IP Logged
Hey everyone, am trying to troubleshoot a python 1401 remote start/keyless system with the added smartstart system.
In a manual transmission vehicle, and MTS mode can be activated no problem.
The system works fine using the remote with the 1401 system (locks and remote start all work)
When I try to use my iPhone4 to control, locks work, but remote start button does not. I get one headlight flash, sounds like a door lock or something moves, then a 4 headlight flash error (transmitter shutdown from install guide).
To be honest I don't really understand what is meant by transmitter shutdown...
Any help would be greatly appreciated, i'd like to get this working before monday morning if possible.
Thanks,
-Dan
bobekdj
Posted: December 24, 2010 at 9:23 PM / IP Logged
btw this is in a chevy aveo5 and we also installed the relay to bypass the ignition.
(since the remote start from my remote works, i would imagine its something with the smartstart module).
-Dan
bobekdj
Posted: December 24, 2010 at 10:04 PM / IP Logged
just went back and double checked my connections and realized the brown ESP connector was used from the smartstart instead of the white D2D connector (has 4 wires instead of 3) and is compatible with the 1401...
..needless to say it fixed the problem, sorry for my noob question.
