fortin evo all
maxcat
Copper - Posts: 211
Posted: January 08, 2011 at 1:04 AM / IP Logged
Hi all,
Wondering if anyone has had some experience with the evo-all bypass module from Fortin. I am trying to program it to a 2003 Honda Accord following the instructions.  I plug in the 4 pin data link with the programming button in, releasing it when the light is red. I then push the programming button one time and it flashes; however, when I push it a 2nd time, instead of flashing once, it continues to flash repeatedly. This is the latest programming sequence from Fortin online.
I have also updated the module to the latest firmware. Any ideas or help would be appreciated. thanks
tedmond
Gold - Posts: 4,610
Posted: January 08, 2011 at 1:17 AM / IP Logged
never had a problem programming the evo's
hold button - insert power wire - LED stays on release button - press prog button once - press again - insert other connectors - turn on ign and led will flash rapidly
Ted
Compustar Expert
maxcat
Copper - Posts: 211
Posted: January 08, 2011 at 1:33 AM / IP Logged
thanks for the reply tedmond, easy procedure however I get the red led flashing right after I press the button the second time, the paperwork says it should again flash once,then turn to ignition, and have it then flash rapidly. I will keep trying.
thanks again for the reply
tedmond
Gold - Posts: 4,610
Posted: January 08, 2011 at 8:32 AM / IP Logged
keep us posted.
Ted
Compustar Expert
