line output converter
bngriss
Member - Posts: 10
Posted: January 31, 2011 at 3:09 PM / IP Logged
Hey Guys,
I have a 2008 Chevy Tahoe w/out NAVI or BOSE.  I will be installing the following w/ the factory HU.
2 JL TW5's
1 JL 500/1.v2
I am looking at the PAC SOEM-T Line Output Converter for the vehicle.  Will this work?  Have you guys heard of/experienced problems before?  Thanks!
Ween
Platinum - Posts: 1,368
Posted: January 31, 2011 at 10:59 PM / IP Logged
hi,
the JL amplifier will accept speaker level inputs, no need to use a LOC.
wiring as such should be in described in the owners manual.
mark
bngriss
Member - Posts: 10
Posted: February 02, 2011 at 6:13 PM / IP Logged
Taking a look at the amp and the owners manual, I don't see the traditional Molex connections for the amp.  I browsed JL's site and they brough me to this, http://www.shopatron.com/products/productdetail/part_number=90435/1451.0   Does that look like something you've seen before?  I got the basic concept down, just don't want to buy something that won't work.  I have also heard that you only want to connect the + connection from the Speaker wire to the Center pin on the RCA and then ground the outside, circle part of the RCA to the chassis.  Is that correct?  I am not a newbie to the install world and have extensive electronic experience.  However, I have never installed a Hi level input like this.  Thanks for the help!
Ween
Posted: February 02, 2011 at 8:42 PM / IP Logged
Page 7 of owners manual. Amplifier Input Section, section 2 Input Voltage Range...."To use speaker-level sources, splice the speaker output wires of the source unit or small amplifier
onto a pair of RCA cables or plugs or use the
JL Audio ECS Speaker Wire to RCA adaptor."
The design of the input section of the JL amplifier allows this.
Thursday, April 23, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
