2006 chevy silverado remote start problem
easternodi
Posted: February 28, 2011 at 5:21 PM / IP Logged
i put a astroflex remote start in an 06 six duramax using a inst-sl+ for the bypass and all it does is start for 5 sec trip the passlock light and shut off the starter throughs a tach signal code also the bypass does not trigger on with the remote start all my conections are correct is there maybe a problem with using the data tach wire from the intsl or am i having programing issues any feedback would be awsome as i need to get this resolved...
jpadj22
Copper - Posts: 100
Posted: February 28, 2011 at 9:31 PM / IP Logged
What kind of bypass are you using?
No better feeling then getting a remote start to work right!
easternodi
Posted: February 28, 2011 at 11:26 PM / IP Logged
it is a fortin int-sl+ firware version 3
brcidd
Copper - Posts: 274
Posted: March 01, 2011 at 10:26 AM / IP Logged
Did the bypass program properly?  Did you use D2D or W2W-  sound like bypass is not getting the Ground when running signal.  If you went by data line, try direct wiring it......
Brcidd - Engineer That Does Remote Starter Installs on the side.
easternodi
Posted: March 01, 2011 at 1:37 PM / IP Logged
the bypass programed you can pulse the door lock wires on it and they work i think i screwed up the programing on the astrostart
Tuesday, April 28, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
