Posted: March 05, 2011 at 5:51 PM / IP Logged
Posted: March 06, 2011 at 11:17 AM / IP Logged
Posted: March 06, 2011 at 1:40 PM / IP Logged
Posted: March 06, 2011 at 4:54 PM / IP Logged
Posted: March 06, 2011 at 8:05 PM / IP Logged
Posted: March 09, 2011 at 11:20 PM / IP Logged
Posted: March 10, 2011 at 12:14 AM / IP Logged
Posted: March 10, 2011 at 1:23 AM / IP Logged
Posted: March 10, 2011 at 6:04 PM / IP Logged
Posted: March 10, 2011 at 7:39 PM / IP Logged
Tuesday, April 28, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved • Privacy Policy & Use of Cookies
I just got the car a month ago so im still trying to figure it all out.
Key ignition problem:
So.. lets review.. When I use the ignition key, the car will crank but will NOT turn over. The car WILL turn over when I use the remote (hold down button 4)
also, the car will NOT turn off when I turn the key off and pull it out. I have to hold down button 4 on the remote to shut the car down.
I tried doing the factory reset on the system but it still wont turn over with ignition key.
In your first reply you started talking about a "starter relay" and "orange wire" could this be something i can try for a fix?
Brake/Shift lock problem:
I just went and double checked my fuses and bulbs as well as checked the stoplight switch to make sure the button was engaging/disengaging when i press the brake peddle. everything looks ok...
p.s. when i purchased the car a month ago i did NOT have the brake/shifter problem but I did have the ignition key start problem...
