hooking up subs to oem head unit
pipes15
Member - Posts: 45
Posted: April 05, 2011 at 12:36 PM / IP Logged
Hello, this might be a stupid question but here goes. I have a 2007 toyota avalon and I am installing two 10" subs with an amp. My question can I get a speaker input from the factory sub? Instead of running wires from the doors? Any help or input on wich way to do installation would be greatly appreciated! Peter.
pipes
DYohn
Platinum - Posts: 10,741
Posted: April 05, 2011 at 7:00 PM / IP Logged
Yes, if your vehicle has a factory subwoofer you can use it to send a speaker level signal to an external subwoofer amp.  Be aware that you will be using whatever OEM crossover settings are employed for the factory sub.
pipes15
Member - Posts: 45
Posted: April 05, 2011 at 7:06 PM / IP Logged
Thanks dyohn! I will try it then.
pipes
Thursday, April 23, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
