compustar cm4200 issues
jonathan.tamayo
Posted: April 13, 2011 at 1:16 AM / IP Logged
Hi all, i installed an cm4200 in my 90 crx(manual tranny). the issue i am having is with the horn output no honk(use a relay every way you possibly can to get to work but nothing), also my door trigger is not setting the brain off when i open the door when car is armed and last the remote start is not cranking everything work light flash dash lights come on fuel pump evrything but no crank and if i am inside the car and remote start it with my foot down on the car fires right up, now the reason i purchased a compustar unit is because i thought u wouldnt have 2 bypass the clutch, i even tryed hooking up the lutch wire to the - status wire from cn2 i normally purchase dei units but this is my first compustar. i have wiring ass followed
cn1
red-12v-connected to wht in column harness
grn/wht-parking lights-connected to RED / grn kick panel
RED / wht-12v(piggy backed red)
white-acc-yellow column harness
blue-not used
grn/red-ign-blk/ylw column harness
blk-ground
cn2
grn/wht-not used
RED / black-starter output-tried to clutch nothing
violet-output to starter kill-to relay
black-- status output-tryed 2 clutch as well
org-not used
wht-horn output-connected to blu/red  (relayed different ways to get horn to work and nothing
cn3
lt blu- e brake- connected to grn/red-kick panel
gry/blk -not used-hoodpin
lt blu/wht-brake-connected to brake wire @ switch
vio/blk-trunk trigger-not used
RED / wht-(-) door trigger- connected to - grn/red-drivers kick
red-(+) door trigger-not used
brn/blk-glo plug-not used
bwn/wht-glo plug-not used
ylw/blk-tach-connect to blue wire @ dist.
cn3-not used
i have programmed remotes, tach learned and put in reservation mode, all dip switchs and jumpers are correct to book, your help is very appriciated and welcome, thanks and hope to hear from someone, i am thinking my unit is bad....
Damn it
JWorm
Platinum - Posts: 2,208
Posted: April 14, 2011 at 11:58 PM / IP Logged
You are probably connecting the RED / black to the wrong wire at the clutch switch. It should be the wire that goes to ground only when the clutch is between 90-100% of the way to the floor.
For the horn... Have you changed setting 3-8 in programming to option 2?
jonathan.tamayo
Posted: April 15, 2011 at 3:45 PM / IP Logged
ill double check my wiring @ clutch and as far as programming i have not i look in the book for programming option for the horn and there was nothing on it but ill try it and see what happens
thanks
Damn it
Tuesday, April 28, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
