spy alarm 2 way 5000m
Posted: April 17, 2011 at 5:10 AM / IP Logged
No. Since you have 6 lock wires you should have internal relays so buying these would be a waste of your money. Set your meter to 20VDC, red probe to a constant 12V+ source in the car, e.g. white at fuse box or ignition loom, then test the white on lock/arm and the WHITE/ black on unlock/disarm. You should get 12V+ each time. If not throw the POS away, because all I can say is I told you so.
saolom
Member - Posts: 15
Posted: April 17, 2011 at 5:51 AM / IP Logged
The manual says 6 wire central locking, will try what you suggested now fingers cross.
what should be done next if I get 12V+.
I'm heading to the car park now as its 100 mtrs away lol.
Posted: April 17, 2011 at 6:06 AM / IP Logged
Wire it as I told you, if you get 12 volts+, then connect it up and away you go.
2 possibilities:-
Stick to your day job.
It's a POS, throw it away.
saolom
Member - Posts: 15
Posted: April 17, 2011 at 7:15 AM / IP Logged
I tested all 6 wires with positive on red test lead and blk on the wires. Was pressing lock n unlock with no power showing! Damn. Thanks for the help anyways. My day just is studying yr 10 lol
Platinum - Posts: 12,488
Posted: April 17, 2011 at 3:30 PM / IP Logged
Earth to earth, ashes to ashes, dust to dust, in sure and certain hope that the POS doesn't come back. It's land fill and you can never get your time back that you spent on the installation.
Page of 3
Tuesday, April 28, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
