can't program cm5000
quakefire
Posted: April 16, 2011 at 1:32 AM / IP Logged
Howdy,
I have a Compustar CM5000 with a 2W9000 two way remote. The installers manual states to enable the turbo timer you go into programming mode you press buttons one and two for 2.5 sec then one and four for the same amount of time. I can't get into the first one, I get fail on the remote and three flashes on the park lights. Can't get it to work.
Help?
quakefire
Posted: April 16, 2011 at 11:57 AM / IP Logged
Sorry it's in a 1994 Toyota Celica GT-Four. All other installed functions are working fine (start, alarm, reservation mode)
Platinum - Posts: 12,488
Posted: April 17, 2011 at 10:42 AM / IP Logged
You must turn on the turbo timer feature from the option menu first before you can turn it on from the remote control. Also, you have to have the park brake wire attached from the CN2 harness
quakefire
Posted: April 18, 2011 at 12:35 PM / IP Logged
Park brake is wired, and functioning (car is a standard trans) Install manual states to enable the option in the menu from the 2way remote by first pressing buttons 1+2 for 2.5 sec then 1+4 for 2.5 secs to get into option menu two. After enabling there you ahould be able to aet the turbo timer from the remote. I get fail on the remote when I try pressing one and two for the first part of the sequence.
Tuesday, April 28, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
