2010 honda ridgeline
lukeylikesit
Member - Posts: 20
Posted: April 23, 2011 at 1:37 PM / IP Logged
looking to install aftermarket head unit on a 2010 Honda Ridgeline so i need the stereo wire diagram thanks.
syl20rochon
Copper - Posts: 298
Posted: April 23, 2011 at 2:30 PM / IP Logged
Are you going to use a after market harness like Metra?
Sylvain Rochon
MECP security specialist
Tech support for remote starters
26 Years of experience counts
I'm here to help.
syl20rochon
Copper - Posts: 298
Posted: April 23, 2011 at 2:40 PM / IP Logged
Satellite Audio Right (+/-) white - black +,- XM Receiver, white 14 pin plug, pins 5 and 13
Satellite Audio Left (+/-) red - green +,- XM Receiver, white 14 pin plug, pins 6 and 14
Satellite Radio Antenna (coaxial cable)
Satellite Radio Ignition orange + XM Receiver, white 14 pin plug, pin 2
Satellite Radio Ground black - XM Receiver, white 14 pin plug, pin 11
Satellite Radio 12 Volts WHITE/ red + XM Receiver, white 14 pin plug, pin 1
RSE Audio Right (+/-) (DIN cable)
RSE Audio Left (+/-) (DIN cable)
RSE Video (+/-) (DIN cable)
Aux. Audio Input Right brown - red +,- radio, gray 14 pin plug, pins 8 and 2
Aux. Audio Input Left (+/-) white - red +,- radio, gray 14 pin plug, pins 1 and 2
Subwoofer (+/-) yellow/black - lt. GREEN/ red +,- radio, gray 14 pin plug, pins 14 and 7
Center Channel (+/-) N/A
Right Rear Speaker (+/-) RED / blue - yellow +,- radio, gray 24 pin plug, pins 7 and 6
Left Rear Speaker (+/-) BROWN / white - RED / yellow +,- radio, gray 24 pin plug, pins 11 and 10
Right Front Speaker (+/-) blue - red +,- radio, gray 24 pin plug, pins 19 and 18
Left Front Speaker (+/-) lt. green - purple +,- radio, gray 24 pin plug, pins 23 and 22
Power Antenna black + radio, gray 3 pin plug, pin 3
Factory Amp Turn-on N/A
RED / black (parking lights), +,- radio, gray 24 pin plug, pins 13 and 1
red (dimmer)
Radio Illumination
Radio Ignition yellow/red + radio, gray 24 pin plug, pin 14
Radio Ground black - radio, gray 24 pin plug, pin 12
Radio 12V white + radio, gray 24 pin plug, pin 24
Sylvain Rochon
I'm here to help.
Wednesday, December 24, 2025 • Copyright © 1999-2025 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
