code alarm, 99 yukon 1500
josh480volts
Posted: April 29, 2011 at 10:22 AM / IP Logged
i have a 99 yukon 1500 4 door i cant figure out how to install the code alarm ca 1151 correctly .im an electrician but dont mess with 12 volt stuff unless its radios or amps. i got the alarm to lock the doors but not unlock and cant figure out the whole door trigger thing, and i think its only going into passive arming and not just regular arming. please help! a whole step by step pic or instructions would be nice.
99 yukon 1500 4x4. lets play in the mud
Platinum - Posts: 7,828
Posted: April 29, 2011 at 4:25 PM / IP Logged
Your truck has the Passlock2 immobilizer system.  Your will need to bypass this to enable a remote start.  Did you purchase / install a bypass module ( or use the relays / resistor method) ?
The door locks on a 4 door should be Type A (+).  I am not familiar with the CA 1151 and don't know if it can directly connect to this type of lock system.  The best way to control the locks is thru a DEI 451M Door Lock module.  They are available "online" for under $10.  The 451M Install Guide is posted in the Downloads section.
Bulldog lists the All Door trigger as :
 DOOR TRIGGER       PURPLE (-)       @ HEADLIGHT SWITCH
Locate and verify this  wire with a DMM and then connect it to the CA 1151 (-) Door Trigger Input wire.
lectricguy
Copper - Posts: 359
Posted: April 29, 2011 at 8:33 PM / IP Logged
The CA 1151 has onboard relays that need to be wired to support Type A (+) locks.   Follow the install guide for 3 wire Positive switched locks.
From the CA 1151 Install guide:
3 Wire Positive Switched Door Locks:
Connect the GREEN/ BLACK wire to the wire that provides a +12 volt signal from the factory door lock switch to the factory door lock control relay.  (LOCK Signal (+))
Connect the BLUE/BLACK wire to the wire that provides a +12 volt signal from the factory door unlock switch to the factory door lock control relay.  (UNLOCK signal (+))
Connect the VIOLET and the VIOLET/BLACK wires to a +12 volt battery source. (+12V Constant in the car)
The WHITE/ BLACK and BROWN / BLACK wires are not required for this type of door lock/unlock system.
Lectric Guy
josh480volts
Posted: April 30, 2011 at 9:37 AM / IP Logged
thanks for the help i think i got it figured out
Monday, April 27, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
